Go Back   Router Forums > General Woodworking > Woodturning and Lathes
Woodturning and Lathes Dedicated to the discussion of woodturning, lathes, turning tools, techniques, projects and sharing of all turning related topics.
Thread Tools Display Modes
Old 09-12-2006, 10:25 AM   #1
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Question what kind of finish
What kind of finish do you use for your pens. I'm currently using Hut finish in a bottle. Don't seem to shine on some woods that I used. Currently turning black walnut, red, and white oak, and hard maple. Don't what to get to exotic just want to use the wood that I have availble. Was thinking though for the maple I seen at wood crafters they have the colored finishes that you see people using for bowls you know red, blue, green and so on wonder what it do for a pen. What would be your opion on it give it a go or let it alone.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline   Top - Reply with Quote
Old 09-12-2006, 08:52 PM   #2
Sidro
Member
Sidro's Avatar
Sidro is on a distinguished road
I have tried a lot of different finishes but now I'm staying with WB Lacquer. This is the product I use but I don't spray it I use a rag or foam brush. Dries in 20-30 mins an I put 3 coats on.
http://www.targetcoatings.com/oxford-spray-lacquer.html
Sid
http://wmyoung.proboards23.com/index.cgi
Sidro is offline   Top - Reply with Quote
Old 09-12-2006, 09:08 PM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Hi Glenmore. I have used spray lacquer and also wiped on deft lacquer. I use it only on rare occasions due to it's toxity and the fumes involved. My primary finish is Enduro Water Based Poly. I apply it per the following link, where I also buy it in the small bottles. I have done about 20 pens with this kit and about out.
http://beartoothwoods.com/catalog/pr...roducts_id=298
Most penturners start looking at other options when they get tired of the shine on the friction polishes fades rather quickly with much handling. I have seen guys use wipon oil poly's as well with good sucess. the key is giving each finish the time to cure prior to any sanding or micro mesh ( I highly recommend if you haven't gotten any yet), you won't believe the difference and lasts a long time.
Hope this helps,
challagan is offline   Top - Reply with Quote
Old 09-12-2006, 10:11 PM   #4
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Glen,
Here is a video you may want to check out also.
http://www.penturners.org/forum/topi...TOPIC_ID=17155
Cheers,
Bob
Bob is offline   Top - Reply with Quote
Pore Filling with Finish jimcrockett The Finishing Touch 6 07-09-2008 08:10 PM
Walnut Burl Veneer… What kind of glue? Nickbee Tools and Woodworking 7 01-19-2008 10:56 AM
Wet sand or paper bag satin poly finish? Nickbee The Finishing Touch 9 11-30-2007 02:34 PM
Suggestions for Finish fibertech The Finishing Touch 5 11-10-2005 11:46 PM
