| Woodturning and Lathes Dedicated to the discussion of woodturning, lathes, turning tools, techniques, projects and sharing of all turning related topics. |
| | #1 |
| Registered User Forum Fanatic | Couple months back I was approached by our Catholic priest and asked if I would turn him a chalice and a Paten. Told him I would if he explained just what he expected me to turn. I turned a few prototypes for him to choose from and he picked this one very enthusiastically. He said do it exactly like this. He wants to use this chalice when he celebrates mass in church. He mixes water and wine, puts in the chalice and drinks it during the mass. I turned the chalice in one day but was afraid to put poly on it cause he is actually going to drink from this chalice. I wrote Minwax and was told it is safe to do if it is varnished with poly and aged for 30 days. Couple friends I wrote and they told me the same thing, One said it's just like drinking from a plastic cup. So I put several coats on. The Paten is made from Walnut, This is also used during the mass..After finishing I asked him if he wants a case to carry the chalice and paten in. He said yes cause he travels to different churches to serve mass, so I made this finger joint box for him. Sorry this is so long but here are the pictures. I turned this over to the priest today and he was very happy. Don't know if this is the best thing I ever turned but this made me the most proud. Mitch |
| | #2 |
| Forum Moderator Supreme Forum King | Really nice work on this one Mitch. Like the box did you use flock or just use stick on felt.
__________________ Glenmore Days without wood working are days not worth getting up for. |
| | #3 |
| Registered User Forum Fanatic | Glenmore Thank you Glenmore. I just used regular felt and glued it on. The box was easy to make but I had a hard time finding the things I needed to make the box. Day I started making it I found out WoodCraft closed up in Pittsburgh. Mitch |
| | #4 |
| Retired Moderator Supreme Forum King | Wow that is beautiful Mitch and a fitting gift for the father. That butternut is gorgeous stuff and I am told it carves very very nicely ... nearly as well as basswood but it's a whole lot prettier! Excellent work Mitch! Corey
| | #5 |
| Registered User Forum King | Mitch great looking pieces. Father is going to like it. I like the box. I wouldn't worry about the finish as far as drinking from it because all finishes are food safe now if cured for 72 hrs. The thing that would concern me would be what the alcohol would do the finish of varnish or poly. I used Waterlox on the one I did for our priest. It is resistant to hot liquids, alcohol, etc. and is food safe for kids when cured.
__________________ Bernie W. Genius is one per cent inspiration, ninety-nine per cent perspiration. |
| | #6 |
| Registered User Forum Fanatic | Corey Thank you buddy. Your certainly right about this butternut being a beautiful wood. It is such a good wood for carvers, like yourself because the grain is so perfectly straight. Something I never knew about butternut is that it is also called white walnut. If you used a light coat of walnut stain on this butternut you won't be able to tell the difference from walnut. I'm most proud that father had confidence enough to ask me to turn this for him. He uses the chalice very often. Mitch |
| | #7 |
| Registered User Forum Fanatic | Bernie Your right on the money, as usual Bern. I am concerned about what the alcohol will do to the inside finish , I was told to use only a couple light coats. If anything happens to the inside finish I believe I could save it. Thanks for the waterlox tip. I forgot about that. Minwax said if any poly was injested it will safely pass through your body as long as you are sure you cured it long enough. I cured it for more than 30 days. Mitch |
| | #8 |
| Official Greeter Supreme Forum King Join Date: Sep 2004 Location: New Lebanon, Ohio "USA" First Name: Dave or "Doc" Posts: 4,699 ![]() | Beautiful work as usual Mitch.
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. ![]() Please edit your profile with a name and location so we can better assist you and make for a friendlier forum. |
| | #9 |
| Forum Contributer Supreme Forum King | This is one of the few times that I'm stuck for words Mitch.
__________________ Harry |
| | #10 |
| Registered User Forum Fanatic | Dave Thank you Dave, this one was something special to me but I am glad I am finished with it. Mitch |
