| This is a discussion on Re-working the Jacaranda bowl within the Woodturning and Lathes forums, part of the General Woodworking category; Because I was successful at reducing the wall thickness of the Jarrah bowl, I was ... |
| | #1 (permalink) | ||
| Forum Contributor ![]() |
Because I was successful at reducing the wall thickness of the Jarrah bowl, I was spurred on to try the same with the Jacaranda bowl. There seem to be three reasons why I left the walls so thick: 1...............Lack of experience 2...............Thinking that a bowl only needed a couple of hours to make 3...............Fear of the bowl shattering. I now have just a little more of #1, so hopefully 2 and 3 will follow. The finish was Shellac sealer followed by two coats of Danish oil rubbed down with 0000 wire wool with Johnsons wax polish.
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ | ||
| | #2 (permalink) | ||
| Registered User ![]() |
Ok Harry ![]() 1...............Lack of experience, That's is understandable doing good!2...............Thinking that a bowl only needed a couple of hours to make, HOW COULD YOU SHAME SHAME SHAME !!! 3...............Fear of the bowl shattering. Never in a million years and even it it did, Have your face gaurd on and your quite safe as there is not a lot to throw or shatter when your down this thin ![]() I now have just a little more of #1, so hopefully 2 and 3 will follow. More time you spend on the lathe you will improve 10th fold plus once the videos get there look out Mr Del Stubbs. The best thing Glenmore said to you was get a lathe.. top marks to Glenmore ![]() cheers Noel | ||
| | #3 (permalink) | ||
Thanks for all that Noel, when I talked about the bowl shattering, I wasn't thinking about it injuring me, rather the foul language that would fill the air, I know that's hard to believe from a gentleman like me, but I do have limits.
__________________ Harry The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking. http://members.dodo.com.au/~sharry02/ Last edited by harrysin; 10-20-2008 at 08:08 AM. | ||
| | #4 (permalink) | ||
Hi Harry, This is why you improve so quickly....you take a previous project out again once you realize it can be improved and think nothing of just going and improving it....that's how masters are made, no doubt. Very nice job....keep it up.....and you'll soon be doing 2 hour bowls with ease and beauty..... Ed.......:-) I now have just a little more of #1, so hopefully 2 and 3 will follow. | ||
| | #5 (permalink) | ||
| Moderation Team ![]() Join Date: Sep 2006 Location: Goodland, Kansas First Name: Bernie Posts: 1,064 ![]() |
Well Harry I must say it again. Well done. You did a remarkable job on this bowl. Beautiful.
__________________ Bernie W. aka Poppa A bad day of turning is still better than a good day at the office. | ||
| | #6 (permalink) | ||
Harry Now I would say that bowl is a beautiful piece of work. Well done , executed beautifully and a credit to your tenacity and search for your turning betterment. Did you ever think of this Harry? If a bowl is too thick especially in the sidewalls like yours were before you reworked them and you have a normal fear of it shattering, there is another thing you can do while reworking the turning and makes the walls thinner and eases the fear. Rework the outside of the bowl down to the thickness you want. This ads to your experience , lessens your fear, and let me tell you this, the two hour bowl is a thing of the past. I practice doing this on bowls I deem expendable and turn them down so far you can see light through the wood. Not using a laser either. I have one but never used it.good practice. If the bowl breaks, so what, that is why I use pine to practice. Nice work Harry, now you need to get your buddy Glenmore back to turning. Mitch | ||
| | #7 (permalink) | |||
Anyway if you did I'm sure there would be some one chasing you around the yard with a broom wanting to hit you am I right ? Marline ?? But yes every one has there limits.Like I said with in no time you will be Del Stubbs mate and turning for the enjoyment it is and showing us here some very creative work you have got me ![]() cheers mate!
__________________ Last edited by Timeman; 10-21-2008 at 05:05 AM. Reason: Typo | |||
| | #8 (permalink) | ||
Thanks again guys, you've given me a pleasant inner glow. Your collage Noel is impressive, even the shot of me tends to make it look as if I know what I'm doing, at least it was taken on a day that I had the right gear on, but just look how I'm holding the chisel! Mitch, it never occurred to me to re-turn the OUTSIDE of the bowls and here is me thinking I was a lateral thinker.
| | #9 (permalink) | ||
Come on Harry what have I told you,always push the boundaries Cheers Pete
__________________ www.chippypah-workshop.co.uk | ||
| A Jacaranda potpourri bowl | harrysin | Woodturning and Lathes | 20 | 10-26-2008 07:38 AM |
| My first Jacaranda bowl | harrysin | Woodturning and Lathes | 16 | 10-26-2008 06:48 AM |
| NE Bowl Presentation | Mitch12 | Woodturning and Lathes | 16 | 06-13-2008 12:27 AM |
| Salad Bowl Set | BernieW | Woodturning and Lathes | 12 | 09-28-2006 10:32 PM |
| Building a New Router Table-What's the Ideal Working Height? | gerrym526 | Table-mounted Routing | 6 | 02-19-2005 11:13 AM |
