Thickness planer stand - Router Forums
post #1 of 21 (permalink) Old 02-09-2009, 08:04 PM Thread Starter
AxlMyk's Avatar
Default Thickness planer stand
This Dewalt 735 sits on the work bench taking up space I could use for something else, so I have decided to build a flip-top stand for it.
I have some cedar 2x4s that I cut to 3', jointed, thicknessed to 1.25" and ripped to 3.25". I plan on using M&T to put it all together. Finally, I have a project to do.
First 2 pics are of the inspiration for the project. Then the wood, and setting up of the tools for the M&Ts.
Name:	Flip Top Stand 104.jpg
Name:	Flip Top Stand 138.jpg
AxlMyk is offline
post #2 of 21 (permalink) Old 02-09-2009, 09:50 PM
xplorx4's Avatar
First Name: Jerry
Mike that is a good looking table. Saw one of those somewhere but don't remember where. Thought of doing that for my jointer, but mine came with a stand so maybe for my Ridgid oscillating sander I can build one. Yours looks really great.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 21 (permalink) Old 02-09-2009, 10:42 PM
RustyW's Avatar
First Name: Rusty
Hey Mike, Thats going to be a nice stand. What locks it in place? I built one from a Shopnotes plan. Put my planer on one side and the miter saw on the other. Sure is a space saver.
Jerry, I have that same ridgid sander. It's one of my favorite tools. But it's always tucked on a shelf in my little garage and hard to get to. I considered putting it on the flip stand. But was afraid the loose parts would fall from under the table while upside down.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #4 of 21 (permalink) Old 02-10-2009, 12:03 AM
Mike, that looks like a good design and material selection for a piece of furniture. I would keep it out of sight of the boss or it will get procured for the house.
Good job!
a1tomo is offline
post #5 of 21 (permalink) Old 02-10-2009, 12:45 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
That looks like a furniture quality job Mike, and far nicer than the ones I've seen in magazines.
Harry
harrysin is offline
post #6 of 21 (permalink) Old 02-10-2009, 05:03 PM Thread Starter
AxlMyk's Avatar
Uh, guys, I haven't built it yet. That is just one I found on the net that gave me the ideas for mine. I found it here;
http://www.bt3central.com/showthread.php?t=39913
Today I started doing the mortises and tenons for the side frames. The top and bottom rails are 30" and I cut the stiles 23.5". The M&Ts are .5"wX1.5h"X2.75l". I'm making the sides 30w"X27t". This will give me room to put wheels under it for a total height of 31". That will slide right under my work bench. I can still install the Ridgid sander to the other side of the table and be able to flip it over to whatever machine I want to use.
AxlMyk is offline
post #7 of 21 (permalink) Old 02-10-2009, 07:03 PM
First Name: Bob
The pics Mike shows look a lot like a plan I'd noticed on the web, here:
http://www.woodstore.net/swivtoolcab.html
I have a long workbench in my garage, and to save space I'm planning to stow rolling tool cabinets underneath it. I was considering one like this, but with only a single tool (next in line is a planer), or something like this:
http://www.woodstore.net/besy.html
Since other tasks have slowed my completion of the garage work to a crawl, I have the luxury of more time for thought.
I'll be interested in seeing how your project evolves, Mike... thanks for sharing.
Bob
thistlefly is offline
post #8 of 21 (permalink) Old 02-11-2009, 01:13 PM Thread Starter
AxlMyk's Avatar
Now it's time to join the outside frames to make the box.
I cut 4 pieces 26" long and made a 7/8" tenon on each end. This gives me room to make a 24" wide table with 1/8" space on each side. The front and back stiles were mortised to accept a vertical edge rail 16" from the top and another horizontal across the bottom where the wheels will be mounted.
AxlMyk is offline
post #9 of 21 (permalink) Old 02-12-2009, 02:40 PM Thread Starter
AxlMyk's Avatar
Today I used the router table with a slot cutter to make grooves for the side and front/back panels. 1/4" cutter and panels. I'll be putting a bottom panel in it to hold junk that has no place else to go.
AxlMyk is offline
post #10 of 21 (permalink) Old 02-12-2009, 07:52 PM
First Name: Bob
Now that the pics we see are Mike's... ... lookin' good, Mike!
Bob
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/axlmyks-stuff/12219-thickness-planer-stand.html
Posted By For Type Date
Installed shelix in DW735 tonight This thread Refback 01-09-2011 08:02 AM
Plans for the drum sander/planer flip cart? This thread Refback 01-08-2011 05:51 PM
Installed shelix in DW735 tonight - Sawmill Creek This thread Refback 05-31-2010 10:31 PM
Installed shelix in DW735 tonight - Sawmill Creek This thread Refback 03-18-2010 10:10 PM
Installed shelix in DW735 tonight - Sawmill Creek This thread Refback 03-18-2010 06:45 PM
Installed shelix in DW735 tonight - Sawmill Creek This thread Refback 03-18-2010 06:41 PM
Plans for the drum sander/planer flip cart? - Sawmill Creek This thread Refback 09-07-2009 12:24 PM
Plans for the drum sander/planer flip cart? - Sawmill Creek This thread Refback 09-07-2009 11:11 AM
Plans for the drum sander/planer flip cart? - Sawmill Creek This thread Refback 09-07-2009 10:32 AM
Plans for the drum sander/planer flip cart? - Sawmill Creek This thread Refback 09-07-2009 10:29 AM
Wonderful Wife (new jointer and planer) xplorx4 Tools and Woodworking 11 11-08-2009 03:29 PM
Thickness Planer Sled pmspirito Jigs and Fixtures 7 11-08-2007 12:44 PM
thickness planer mounting reds_21 Tools and Woodworking 4 08-07-2005 09:14 PM
Thickness Planer Wood Defect....... reds_21 Tools and Woodworking 3 05-15-2005 07:47 AM
Planer stand ideas? Mike Tools and Woodworking 8 04-05-2005 08:22 AM
