Festool 125mm sander for $99 Promo - Router Forums
 2Likes
post #1 of 19 (permalink) Old 10-05-2016, 12:02 AM Thread Starter
Default Festool 125mm sander for $99 Promo
Looks like Festool has a promo going on for their little 125 mm (5") sander.
It's a special edition of their ETS 125 REQ
for $99.00 plus a $50 voucher to apply to future additional tool purchase.
All indications are that it's 'for real' and it's not a 'poor boy' version of the ETS 125 REQ which normally goes for much more. (I paid roughly $200 for mine in 06)
Festoolproducts dot com has 'em, I assume their other vendors with show as well.
Want one, try one, need one.. now's a good time.
No connection with anyone on this, just think their stuff is pretty good and the opportunity is there.
Cheers
TomE is offline
post #2 of 19 (permalink) Old 10-05-2016, 12:20 AM
First Name: Clay
I would love to try one, but the 500$ vac makes that a no go.
fire65 is offline
post #3 of 19 (permalink) Old 10-05-2016, 02:31 AM
That's a hell of a deal. I have 4 or 5 ROSs between Dewalt and PC but I'm thinking that I might just go for one more at that price. My theory is that in the long run it's cheaper to have more sanders so that I don't keep changing grits on the same sander and wear the velcro pad out which is expensive to replace.
post #4 of 19 (permalink) Old 10-05-2016, 09:37 AM
Wood Chip's Avatar
First Name: Gary
Default Festool ROS deal
Does it not work with other vac systems?
Wood Chip is offline
post #5 of 19 (permalink) Old 10-05-2016, 10:43 AM Thread Starter
Sure it can.
I've hooked mine up to Fein, Festool and I even used a funky ole Shopvac at one time.
Might have to jigger up some adaptive hose fittings because Festool does design the dust ports to fit their stuff.
TomE is offline
post #6 of 19 (permalink) Old 10-05-2016, 11:41 AM
First Name: lee
Originally Posted by TomE View Post
Sure it can.
What did you have to do to make it work with a Fein vac? Is there an adapter?
coxhaus is offline
post #7 of 19 (permalink) Old 10-05-2016, 11:59 AM
Dejure's Avatar
First Name: Kelly
I have seven sanders and none of them have a vac. The only reason I'd run a vac with this is to limit loading of the paper, since I have a sanding station that removes the need for other dust collection.
Meanwhile, there is the polishing aspect too. I don't know if this one does it, but other Festool ROS are used for polishing and I suspect this one would too.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #8 of 19 (permalink) Old 10-05-2016, 05:17 PM
chuckgray's Avatar
First Name: Chuck
My purchasing constraint seldom wins out when confronted with a tool bargain...I went ahead and ordered one...After all, I only have one ROS right now and everyone knows that you need at least two, right?..
Thanks for the post Tom!
Dejure and TomE like this.
chuckgray is offline
post #9 of 19 (permalink) Old 10-05-2016, 07:01 PM
First Name: Earl
same thing I did last night--same thought process. Hope the Kool-Aid tastes as good as it looks!!
earl
greenacres2 is offline
post #10 of 19 (permalink) Old 10-05-2016, 10:33 PM Thread Starter
My Festool hose fits the Fein Vac, so I just use that.
I'll have to poke around and see if I can fit the Fein hose to the sander's port.
The other shop vac connections were usually cobbled together using bicycle inner tubes, tape and such. We've even used slices of paint roller covers to adapt hose ends to miter and jobsite table saws.
TomE is offline
Cheapest I've Seen Any Festool Dejure Tools and Woodworking 23 08-22-2017 03:16 AM
I Think I'm In The Market For A New Orbital Sander Jerry Bowen Tools and Woodworking 44 05-20-2016 04:13 PM
Makita Rail System Router Compatibility Marcel M Portable Routing 53 10-10-2012 02:35 AM
Help Help finishing Sander??? TheOakDude Tools and Woodworking 7 10-23-2011 06:07 AM
My Sander Arrived!... challagan Tools and Woodworking 9 04-26-2007 10:50 PM
