10" saw blade deal? - Page 2 - Router Forums
 11Likes
post #11 of 26 (permalink) Old 12-26-2016, 07:25 PM Thread Starter
First Name: Quenten
I was wanting it for a ripping blade, but I see that it is for crosscutting. Great info in that link Stick!
Tonto1 is offline
post #12 of 26 (permalink) Old 12-26-2016, 07:45 PM
Originally Posted by Jack Wilson View Post
Stick, I've saved this and may refer to it on occasion, but I'm pretty sure my blades on my mitre saws have a positive hook angle.
so put the correct one on...
post #13 of 26 (permalink) Old 12-26-2016, 07:46 PM
Originally Posted by hawkeye10 View Post
I don't buy anything at Sears. Going to Sears to buy tools is like going to the Dollar Store and buying tools. Neither one has a clue.
ditto...
at least the CS at the dollar store is leagues ahead of sears...
RainMan 2.0 likes this.
post #14 of 26 (permalink) Old 12-26-2016, 08:14 PM
Jack Wilson's Avatar
First Name: Jack
But they work great!
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #15 of 26 (permalink) Old 12-26-2016, 08:16 PM
Quenten that Freud 60 tooth is an excellent crosscutting blade for the table saw and at that price is a steal. For ripping you want max 30 tooth with high hook angle. The more teeth you have the more power it takes to drive it and more teeth means smaller saw gullets so the gullets on those blades load up very quickly with sawdust and when they do it creates friction on the sides of the cut and the blade gets hot and will start warping. I ruined a pretty good Sears blade that was 60 tooth just in that fashion. You also have to make sure that the blade is designed to cut 3" deep if you intend to use it that way. Freud makes 2 blades that are nearly identical except that one is only meant to cut material 1" thick. I think the Sears blade was only meant for cutting panels (i.e. less than 1") but that's one of the issues with buying from Sears is that you don't always get all the info that should be included. I also have an 80 tooth melamine blade from Sears and it has been a pretty good blade. It may be starting to get a little dull finally but it was a reasonably good blade so I wouldn't hesitate to buy a Sears blade if the price was right.
Herb Stoops and Job and Knock like this.
post #16 of 26 (permalink) Old 12-26-2016, 09:28 PM
and a negative rake will work better..
and safer too...
post #17 of 26 (permalink) Old 12-27-2016, 12:11 AM
Originally Posted by Marco View Post
If neither one has a clue then why do they locate their tools next to small appliances? Answer me that Mr. Hawkeye! ...
...So someone who knows little about appliances and nothing about tools can cover the floor in both departments. Got to keep labor costs in line by golly.
post #18 of 26 (permalink) Old 12-27-2016, 12:49 AM Thread Starter
First Name: Quenten
Thanks Charles, you guys are great. I didn't realize how much there was to learn about wood working! After looking at the blade on my table saw, it appears to be for crosscutting as well. So I will need to pick up a ripping blade. I will be on a very limited budget for a while so I really appreciate you guys sharing your knowledge/experience with me. I think I will pick up that Freud blade since it is a good deal. I'm sure I will need it before long. I'll start looking for a ripping blade also.
Tonto1 is offline
post #19 of 26 (permalink) Old 12-27-2016, 01:19 AM
If you want a really great blade, get the Freud glue line rip blade. Amazingly good blade. I also have switched to the full kerf rip blade Freud offers in their industrial line. Not quite as fine a finish on the cut as the Glue line, but man, no distordeflection tion of the blade, ever. One more thing about saw blades, I recently realized I was not raising the blade quite high enough when doing a rip cut. Now I try to get the blade high enough so most of the gullet is above the work piece, which allows the gullet to carry more sawdust down into the dust collection system in the saw. A surprising difference with abut 1/4 inch higher setting.
Herb Stoops and chuckgray like this.
post #20 of 26 (permalink) Old 12-27-2016, 02:20 AM
Here are some pretty good deals on blades. I've dealt with this guy several times and he's very good to deal with. I've only had the most positive of experiences so far.
Delta 10 x 18 FT Grind Carbide Saw Blade 35-611
Craftsman 29283 Dyanite Carbide 10" x 40 10" x 28 Tooth Circular Saw Blade Sears blades but 2 for $16 is cheap.
An Interesting Visit With A Lenox Band Saw blade Rep Jerry Bowen Tools and Woodworking 11 03-06-2019 07:32 PM
Bosch 4100 EQUINOX400 Tools and Woodworking 23 09-16-2014 02:39 PM
7" Dado blade on a 10" Table Saw?? JudgeMike Starting Off 18 12-02-2012 09:22 PM
10" blade selection?? jeep_man Tools and Woodworking 27 04-10-2009 05:57 PM
Forest 10" 80 tooth Chopmaster Blade rstermer Tool Reviews 0 05-13-2008 03:31 PM
