Disposable TS Blades - Page 2 - Router Forums
 8Likes
post #11 of 12 (permalink) Old 03-17-2017, 11:46 AM
I don't buy that kind of bargain anymore. Almost never have good results for long term use. And if I'm cutting some expensive stock, I want good blades in a carefully set up saw. For ripping, I am very fond of the Freud glueline blade. But I also have a full kerf Freud blade for general use and crosscuts. The risk of flying teeth just isn't worth it to me. And you know that the little bit of carbide on the tips is the lowest quality they can find. A really good blade can be resharpened 2--4 times.
Using a cheapie blade for construction use makes sense to some, but construction grade lumber gets dumped in bulk at a job site and and begins collecting who knows what. Sounds like a setup for an on-the-job injury.
That's how I see it anyway.
Nickp likes this.
post #12 of 12 (permalink) Old 03-17-2017, 12:31 PM
Originally Posted by Tagwatts View Post
Sounds like a great buy. I am new to doing wood working of any kind. One of the things, I have learned so far is, if it is a super great buy and it is cheap, it is just cheap. Anymore, I stay away from any thing that is super cheap. However, having said that, looking on the the sight and then looking at the review chart, they rated a 4.5 out of five. That is a great rating for anything you buy. So this may be the real deal.
unless you get hit by a tooth or teeth...
Ray Newman and Nickp like this.
What saw blades do you like? Mike Tools and Woodworking 40 10-15-2015 11:06 PM
Freud saw blades... Stick486 Tools and Woodworking 22 08-28-2015 07:34 PM
Jerry Wants To Talk About BS Blades Again Jerry Bowen Tools and Woodworking 24 08-14-2014 09:51 AM
Sharp planer blades paduke Tools and Woodworking 3 05-17-2012 06:59 PM
