Old Craftsman Radial Arm Saw - Router Forums
 6Likes
post #1 of 22 (permalink) Old 03-29-2017, 11:22 AM Thread Starter
First Name: Quenten
Default Old Craftsman Radial Arm Saw
Hey guys, one of the surgeons has an RN that assists him in the OR & knows I'm getting into woodworking.
She inherited her dads RAS Model 509399. The manual says model 113.197411. It comes with an assortment of blades (9, one of which looks like a Dado blade). It looks very clean, has a blade guard (so recall repair must have been done). She says it's in the way in her carport & asked me to make her an offer. What would you guys say is a reasonable offer. I have no experience with used tools. She says her dad was very particular with his tools and always kept them immaculate. I can post pictures when I get home tonight.
Tonto1 is offline
post #2 of 22 (permalink) Old 03-29-2017, 11:36 AM
50~75$$$
there are many of them out there...
Stick486 is offline
post #3 of 22 (permalink) Old 03-29-2017, 12:19 PM Thread Starter
First Name: Quenten
Thanks Stick, are you familiar with this saw. I'm not finding anything on the Net about it.
Tonto1 is offline
post #4 of 22 (permalink) Old 03-29-2017, 12:38 PM
not surprising.. it's old...
parts are pretty much non existent ...
Stick486 is offline
post #5 of 22 (permalink) Old 03-29-2017, 12:59 PM
vchiarelli's Avatar
First Name: Vince
@Tonto1
Quentin - that looks like the saw my dad had, which was the Sears anniversary special and came with that lower cabinet - cost (Canadian) was somewhere between $1000 - 1200 at the time - I don't remember specifically.
He wanted to give it to me but I declined - I had a SCMS. He attempted to sell it but couldn't and eventually gave it away. Going price in our area (Southern Ontario) is somewhere between $50 - $100 as Stick says.
In case you're interested here's a link to the product manual:
Sears Saw 113.197411 User Guide | ManualsOnline.com
vchiarelli is offline
post #6 of 22 (permalink) Old 03-29-2017, 02:27 PM
About what Stick said. The SCMS has pretty much replaced it. They were never particularly accurate. The most common use was on construction sites for repetitive cut off as in when cutting cross bracing for floor joists. You had to be pretty careful when using them not to put torque on the handle or you would pull them off square.
post #7 of 22 (permalink) Old 03-29-2017, 03:31 PM
I've mentioned in the past; that's the beast that nearly took my hand off. The On-Off switch was inaccessible from where I was standing doing a ripped dado.
My own B&D RAS has the switch mounted on the end of the arm, where you can always reach it.
Sorry, but after that experience you couldn't give me a Craftsman RAS.
DaninVan is offline
post #8 of 22 (permalink) Old 03-29-2017, 04:18 PM
First Name: Richard
I agree with all the above. Not very accurate and not worth much.
Shop guy is offline
post #9 of 22 (permalink) Old 03-29-2017, 06:38 PM
Default On the Other hand...
If you've got the space for it, it'd make a nice disc sander or even a drum sander if you can get a chuck to fit, or otherwise add a drum.
The Radial Arm Saw -- a Guide of Sorts - 6
Radial Arm Saw Sanding Disk
DaninVan is offline
post #10 of 22 (permalink) Old 03-29-2017, 07:16 PM
roofner's Avatar
First Name: Gary
I bought mine for 75 dollars and got one of the last free kits. I love mine its in excellent shape no play in carriage . I would not pay any more than 75 dollars. Mine was accurate if you align blade. Nice thing about them cheap fence just throw away. Need a new one take a 4 ft piece of 3/4 mdf rip a 2 1/2 inch piece. Clamp in place and cut through measure from the right side of curf to length you want put a stop block. Much better cut than my sliding compound because much better support don't get the chip out. However pain in the ass to cut angles so I use slider for angles.
tomp913 likes this.
roofner is online now
Craftsman Electronic Radial Arm Saw Txwoodman1 Tools and Woodworking 9 03-31-2014 08:19 AM
For Sale: Craftsman Electronic Radial (Arm) Saw MAFoElffen Woodworking Classifieds 13 11-16-2013 05:44 PM
Radial Arm Saw Craftsman Radial Arm Saw 113.29461 Dmeadows Craftsman Manuals 0 09-09-2013 12:17 PM
Drill Craftsman Radial Arm Drill Press 149.21334 RichKB Craftsman Manuals 0 11-15-2012 04:50 PM
Craftsman Radial Arm saw (1980's vintage) motor smokes jmoore65 Starting Off 6 09-20-2010 09:01 PM
