Trend Pivot Frame jig - Router Forums
post #1 of 13 (permalink) Old 02-11-2011, 11:30 PM Thread Starter
Default Trend Pivot Frame jig
This thing has dropped about $50 in the last couple of weeks. Don't know if it fits the T-4 either. Just an FYI
http://www.amazon.com/Trend-PFJ-SET-...d=OIRQ8BUMJRXI
John Schaben
jschaben is offline
post #2 of 13 (permalink) Old 02-12-2011, 12:12 AM
Hi John,
You might like to change the title of this thread if you can.
The title says "Triton" but the ad refers to a Trend PFJ?
Sydney, Australia
jw2170 is offline
post #3 of 13 (permalink) Old 02-12-2011, 12:56 AM Thread Starter
Originally Posted by jw2170 View Post
Hi John,
You Aussies are a sharp lot, Harry caught me too.... Must have had a brain cramp on that one....
I don't think I can edit the title, Maybe Mark or another admin type can.... Humble apologies.
John Schaben
jschaben is offline
post #4 of 13 (permalink) Old 02-12-2011, 07:24 AM
TwoSkies57's Avatar
there ya go John.....
Skipper the Penguin
TwoSkies57 is offline
post #5 of 13 (permalink) Old 02-12-2011, 11:59 AM Thread Starter
John Schaben
jschaben is offline
post #6 of 13 (permalink) Old 02-12-2011, 12:47 PM
T4 router below
http://www.youtube.com/watch?v=18CUKZo2JUE
post #7 of 13 (permalink) Old 02-12-2011, 11:54 PM
First Name: Bob
T4 router below
YouTube - Trend Pivot Frame Jig
Sweet and clean handmade copy, BJ... do you have any measured drawings and specs?
Bob
thistlefly is offline
post #8 of 13 (permalink) Old 02-13-2011, 04:05 AM
Mike Wingate's Avatar
First Name: mike
I used to be pedantic and needed sizes and specs to confirm my design before manufacture. Experience will tell that you to use what you have to do the job. The bolts could be a larger dia, the rails whatever size you have, in plastic, metal or wood. Bob's is a good copy with what he knows are improvements. Collect a few pictures of the beast and have a go. If it works well, great, if not make adjustments to the design. I use solid bars rather than studding. My "wheels" are 1 piece, etc. Go for it. My major mistake was to make things too big and chunky. So strong enough.
Mike Wingate is offline
post #9 of 13 (permalink) Old 02-13-2011, 04:22 AM
Hi Bob
No plans or drawings, sorry,I use the manual and a bit of math to get the specs..
I have updated it a bit with red knobs and solid longer rods.(5/16" diam.)see 2nd.link below, for quicker adjustment and so the router can slide on the rods easy.
Note....the T4 router works well for this jig,it has a 6mm hole drilled and taped in the base that many routers don't have,I used a 1/4-20 all thread and just recut the threads on one end to fit in the (6mm) hole in the base for cir.work..
Manual ▼
http://www.routerforums.com/jigs-fix...trend-jig.html
Bob
post #10 of 13 (permalink) Old 02-13-2011, 06:48 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
What increase in speed did you achieve by changing to red knobs Bob?
Harry
harrysin is offline
Trend Jig bobj3 Jigs and Fixtures 33 07-27-2010 10:31 AM
