MuscleChuck - Page 2 - Router Forums
 14Likes
post #11 of 20 (permalink) Old 07-02-2015, 09:45 AM
Hentie, I am pretty sure that the breeding grounds for routers is Colorado. Our late friend/forum member BJ (BobJ3) and Stick seem to have the largest herds. Hmm, I will have to ask Stick about stud fees...
I am building my herd; some day I need to get all of my routers in one photo. Here are some of them.
rcp612, Cricket, Roy Drake and 1 others like this.
post #12 of 20 (permalink) Old 07-06-2015, 04:03 PM
Country: South Africa
First Name: Hentie
I think I just realized I definitely found the right forum.
jw2170, Semipro and old55 like this.
lowracer is offline
post #13 of 20 (permalink) Old 07-06-2015, 07:07 PM
paduke's Avatar
Originally Posted by lowracer View Post
i think i just realized i definitely found the right forum.
yeaaap lottsa of did
paduke is offline
post #14 of 20 (permalink) Old 07-06-2015, 10:05 PM
The Hobbyist's Avatar
First Name: Joe
I just ordered four seta for my four Bosch routers. I hope they are as great as they appear in the sales videos.
The Hobbyist is online now
post #15 of 20 (permalink) Old 07-06-2015, 10:51 PM
Type 4's Joe? They work great.
Cricket likes this.
post #16 of 20 (permalink) Old 07-07-2015, 03:28 AM
Honored Member
harrysin's Avatar
First Name: Harry
Personally I can see no reason for more than four routers, one under the table, a trim router, one for hand held use and a spare one. I always joked to our late friend Bobj3 that he had one for each day of the week plus several spare just in case.
My comments refer to hobbyists, Pros. are different and have several routers set up with different bits which of course speeds up the job and time is money.
I often wonder what determines which router is going to be chosen for today's job and why, is it a choice of colour or the the most convenient to reach! Then again, could it be that they are collectors rather than routologists?
Harry
harrysin is offline
post #17 of 20 (permalink) Old 07-07-2015, 08:57 AM
First Name: Hentie
I don't have a trim router - so the hand held ones works out to one with oomph, one without oomph (where you would use the trim router) and one with a guide bushing (because I got an el-cheapo guide bush, so cannot easily switch them around.
then for the mounted ones, I don't have a standard router table, never had one. I was going to finally build one this year, even bought a triton router to mount in it. Then got a Woodster BS52 instead - busy setting it up. I have the 2 overhead routers. my own I had for around 10 years, and the other similar one bought from a friend's estate. there is a router mounted in the router lathe. then I have one I am going to mount in the radial arm saw to make easy cross grain dados and angular dados.
So the triton that was going to go into the router table is now one of the handhelds, and that allowed me to give away the older handheld router to a needy guy.
lowracer is offline
post #18 of 20 (permalink) Old 07-07-2015, 09:29 AM
Honored Member
harrysin's Avatar
First Name: Harry
That makes good sense Hentie, a purpose for each one.
lowracer likes this.
Harry
harrysin is offline
post #19 of 20 (permalink) Old 07-07-2015, 02:37 PM
First Name: Larry
Mike, that's a fine stable of routers you have their. I see some on my wishlist. Since you have several different companies represented, I'm curious how you would rate your #1,#2, #3 choice in the large plunge routers.
Stargate is offline
post #20 of 20 (permalink) Old 07-07-2015, 08:53 PM
Larry, it's a very tough choice and no one router has everything perfect. All have their strong points as well as weaknesses. Two of the routers are fixed base while the rest are plunge. Is price an issue? How is the router to be used? Free hand, mounted or ski jig? Dust collection? Using the routers with after market accessories can change the outcome of the ratings. IE.. both PC's and the Milwaukee have no dust collection accessories. Mount them on a Betterley Stacc-Vac or in a table with good dust collection and it becomes a non-issue. How you will use the router and how you prefer the controls to operate is what you should make your choice on. They all work. This may sound like I am avoiding answering but I am not.
Based on my needs I would rate the Bosch 1619EVS best for all round use. It has the best turret design, good dust collection accessories, the deepest plunge cut and the largest base opening. It is the only router with a plunge spring defeat feature that lets you change from table to hand held routing by popping the router out of the table and releasing the lever lock. (Mounting plates work fine as a base for free hand routing)
The Makita RP2301FC would be a close second. Harry posted his solution for the poor turret design.
For free hand use I would choose the Festool OF2200EB as my first choice; the PC 7538 and then the Bosch 1619EVS.
The Triton TRA-001 was designed for table mounted routing; drop it in the table, hook up the dust collection hose and go.
The Milwaukee 5625-20 has a rapid height adjust feature that is great for fixed base routing, it works well in a table or mounted in a lift.
The PC 7518 has long been the king of the router lift but there is a new challenger: the Portamate. More on this soon.
The DeWalt 625 is the world's top choice for use with the Woodrat.
Last and by no means least is the Hitachi M12VE; this is the value leader with it's low cost and good all around performance.
Now get your passport and come rate them for yourself.
Stargate likes this.
Musclechuck Ken Bee General Routing 28 07-20-2015 12:28 PM
MuscleChuck vs Whiteside Eliminator...huh...? Nickp Router Bits - Types and Usage 38 06-09-2015 11:40 PM
Musclechuck N'awlins77 Jigs and Fixtures 28 02-13-2015 07:39 AM
Musclechuck hex key storage 48394 Table-mounted Routing 3 07-15-2014 08:24 PM
At last, a MUSCLECHUCK for the early TRITON routers harrysin Lobby 1 06-07-2014 01:18 AM
