Dug this router out to (perhaps) put some extra T+G in some salvaged oak flooring, as I fit the jigsaw puzzle together.
Also found a 76-400 router table and a 76-320 guide (without the threaded rods, but not a show-stopper).
All donated by a friend/client, from her old Dad's tools in her house, and the nice 'Router Craft' book from B+D (by George R. Drake, Part#76-300, Rev.4. 5/80) which covers several uses and handy jigs. Some on Amazon for $1.99 spiral-bound.
I only had a Craftsman (that I've used a few times, and bits), so more capability, if it goes together and (still works!)
I just picked this router up at a flea market with a bit stuck in the collet. I don't have a wrench that can fit on the bottom collar, and the diagrams don't tell me what size(s) the wrenches that came with it are. So that's my question: What size wrench fits the bottom collar? (And I guess what size fits the top collet, for reference?)
Vince is right, D. I made myself a couple of crude wrenches from 2" flat steel stock, with hacksaw, Dremel cutoff wheel and file (but NOT pretty, and they work.)
Soon after, I found a stepped double-ended flat wrench at a 'Japanese 99c store' called Daiso, in Temple City CA, where just about everything is $1.50 instead of 99c.
This one is marked in mm, I got out my Chinese Harbor Freight stamps and marked the equivalent inch sizes.
I'll get another next time I'm down that way.
The cheeks of the router only allow about one-flat rotation, but it's usable that way.
I mounted the router on the table, and the table on a little portable worktable, and put a Home Depot 'bucket-vac' on the bottom shelf, cobbled-up a plastic bottle and hot-glue hood to hold the hose next to the source of chips, and IT WORKS!
FWIW, once you can loosen the collet, hold the one wrench on the motor, grab the shaft of the bit with pliers, and wiggle it out; a dab of Liquid Wrench may help. Enjoy, rout safely!
The two wrenches are the same size - my wrenches aren't marked but a measurement shows them to be ~13/16. You could take the collet with you to a store and test to see what fits.
The previous post to yours was in 2016. Would suggest that you start a new thread seeking advice as you may or may not get a reply in this one. There is no issue in starting a new one and I’m sure someone will be able to give you advice. Enjoy the forum.
Related Threads
747K posts
128.1K members
Since 2004
