Circular Saw Bosch PKS 54, PKS54CE, PKS66, PKS66CE Circular Saws - Router Forums
 1Likes
  • 1 Post By reuelt
post #1 of 3 (permalink) Old 05-06-2018, 03:34 AM Thread Starter
First Name: Reuel
Default Bosch PKS 54, PKS54CE, PKS66, PKS66CE Circular Saws
I have a VINTAGE Bosch PKS 54 circular saw with small 160mm blade. Bought from a cash converter for only AUD45 then overhauled & lubricated it.
Very accurate, powerful and safe to use - as it has a moving riving knife. I have cut 35mm Hardwood panels with it.
File Type: pdf Bosch pks_54 Pks_66 Circular Saw User Guide.pdf (3.01 MB, 181 views)
Cherryville Chuck likes this.
reuelt is offline
post #2 of 3 (permalink) Old 05-14-2018, 01:53 AM Thread Starter
First Name: Reuel
Default How do you overhaul a circular saw?
A portable power tool often use the Universal motor with armature + carbon brushes. There are also switches and with contacts etc.
The greatest enemy of such power tools are DUST including Carbon powder + hardened or melted grease and RUST.
With a good dust chute and quality shopvac sucking though a mini-cyclone, your portable power tool will last longer.
I like to pay for trade quality Circular saw and routers because they use good quality hardened bushes and bearings but wood chips can damage them all the same.
By overhauling, I mean cleaning up all wood chips, worn metal , hardened or melted grease, remove all carbon dust from the armature and use a pen shaped "glass fibre brush" to clean all electrical contacts including the armature and switches. Some fine sandpapering to make sure that trigger switches will never jam in the on position. Flatten the carbon brush ends and replace if necessary.
After that, bearings & gears rusts are loosened with Premium grade WD40 and regreased or re oiled.
Blade rusts are sanded off and blade lubricated with DRY-LUPE.
All adjustments are readjusted so that 0 or zero angle means exactly zero.
The best tool is the pen shaped "glass fibre brush". I have been able to resurrect a dead vacuum cleaner by just cleaning the armature with it. It give a "brand new like bright shinning armatures free of carbon dusts that often shorted the armature and slow down and stop the motor.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #3 of 3 (permalink) Old 05-14-2018, 06:28 AM Thread Starter
First Name: Reuel
This fiberglass pen has resurrected computers, a vacuum cleaners and some powertools from the dead by just cleaning the electrical contacts.
Best Regards
Reuel
reuelt is offline
Bosch JS572EL and JS572EBL jig saws Mike Tool Reviews 6 07-04-2015 06:05 PM
Bosch PKS 65 - seeking manual thomases Tools and Woodworking 3 09-12-2011 05:34 PM
Bosch circular saw crquack Tools and Woodworking 1 04-25-2009 07:32 PM
