Don't forget you need to cut all those dowels. Keep your tolerances tight so everything fits together or I'll blame it on you if the mechanisms don't work.
If it all goes together reasonably well, it shouldn't be a problem between MEBCWD and myself. You don't need a CNC for this, but I'm hoping it makes the pieces fit together better. Besides, I wanted to see if I could make parts that could be assembled into a final product like others have done.
The biggest key to cutting pieces with a CNC that need to fit tightly together is to really know the cutting diameter of the bit you are using. First you have the physical diameter, which on regular commercial bits can be a couple thousandth or more small that make things too tight. Next you have your actual rotating run out, which can contribute another couple thousandths using a router.
Draw a square in CAD that fits to your micrometer (don't use a caliper). In my case I have a 2" micrometer, so I use a 1.5" square. On a piece of material, cut two squares; first using the inside and second using the outside. You can dog the corners or chamfer them. If by some stroke of magic they fit together then you can call it done. Most always you need to measure the "inside" square, subtract that from the 1.5" and then divide it into two. Add that value to your tool diameter and repeat the cut. It should then fit.
I have a place that sharpens my bits and uses a laser optical comparator for a true diameter measurement. Never have had a "good" brand box store end-mill not be small. It seems $80 is where you start getting accurate to a thousandths. But even so I do the square test in order to know the run-out cutting diameter.
You have a place in the area that sharpens bits, or do you send them out. What's the cost?
If I don't break them first, I've just been pitching them when they get dull. Course, I only got a few "high end" ones.
Got a couple of more sections put together and a couple off to the side freshly glued and clamped. The fun part, seeing if they all mesh together, is getting closer.
Got the main parts put together in sections and dry fit to see if it all worked. I added screws even though the plans said to just use glue. Still got to add the trim and of course paint. I'm thinking apple red.
I would never make it as a toy maker. This was a lot of parts to fit together on a small scale.
Yes we did , Mike!!!! I made a couple "changes" to the front of the box and cab protector to make it a little sturdier. And theres a mistake on one of the fuel tanks (cap on wrong side) on the plans. But the basic parts all fit. You had it nailed pretty good.
I am sure Oliver has some pieces of ACME brand equipment you could use
Related Threads
747K posts
128.1K members
Since 2004
