Hello to all, I am new to this field. actually I am building a CNC carving machine for wood working. the machining dimensions will be 2500mm*1300mm*200mm and structure will be made up of plywood and aluminum plate. I am having two barriers right now
(i) should i go for rack and pinion drive or ball screw is a good option.
(ii) How much torque stepper motor will do the work.
If any one can suggest me it would be a great help..
thanks
thanks
