-Never bottom out a bit. If you put the bit in too far, then the collet cannot pull down on it properly to tighten. It can also score the bit.
-The bit has to be fully through the collet. Make sure the bit passes all the way into the collet, so it can get a solid grip. I personally try to put as much bit into the collet as possible and still accomplish the job. I don't know if it is scientific, but I think the shorter bit extension (or 'lever arm') puts less stress on the router or spindle bearing. I guess you could think of it as a cantilevered load.
The minimum of the shaft I make sure is in the collet is enough to fill the inner tapered plug of the collet.
If your bit is wider than the shaft and has a fillet where the shaft meets the wider sharpened parts make sure you aren't clamping down on that fillet.
As Doug said, use 100% of the collet. Somewhere around 75 or 80% or less and you risk damaging the collet. More than 100% through doesn't gain anything holding wise but as Doug said it causes less shear force on the shank and less stress on the bottom bearing. If you notice, 1/4 shanks are usually fairly short and that's not an accident.
I've gotten into the habit of removing the collet entirely - separate from the router, and then inserting the bit until I can see there is 1/8" of free space within the collet and below the bit shank. Next, I just put the collet together and tighten with the two wrenches provided by Porter-Cable and I'm using P-C 690's.
I am the voice of bad experience, bottomed out a bit and tightened it up. Took quite an effort to loosen the collet after that.
Now I bottom it and bring it out 1/4" before tightening.
Steve.
Related Threads
747K posts
128.1K members
Since 2004
