Cedar owl. - Page 2 - Router Forums
 27Likes
post #11 of 18 (permalink) Old 02-20-2017, 10:18 AM
MEBCWD's Avatar
Originally Posted by Scottart View Post
Not sure how you all model of shapes like this.
I lay a ruler across one dimension. Snap a photo. Load that photo in aspire, and scale the photo to the width indicated on the ruler.
For this piece I dropped an oval on it 24 " wide (widest part of the slab). Than used node editing to contour the oval to match the image. I set an easy to find cross section on the slab over dead center of the work area. Finally I rotate it to get an easy alignment mark for horizontal alignment. In this case, the bottom of the burl is ran on my X axis.
Scott using a picture of a special piece you will be carving scaled in Aspire helps tremendously to make sure you place everything in the correct location so you have enough material to cut the models.
I also have pictures of end grain cutting boards in the bitmap files so I can show a customer what a custom inlay will look like in a cutting board before they place their order.
I like the fact that you are under cutting behind portions of the model to make it stand out and add depth to the overall project. Another great carving!
Name:	MBC art piece.JPG
kp91 and Scottart like this.
MEBCWD is offline
post #12 of 18 (permalink) Old 02-20-2017, 11:34 AM
kp91's Avatar
First Name: Doug
What an awesome tip! I feel foolish for not figuring that one out, and wasting time 'cutting air' over a piece to see where the image would land.
Scottart likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #13 of 18 (permalink) Old 02-20-2017, 11:38 AM Thread Starter
Scottart's Avatar
First Name: Scott
have done that cutting air thing. You can also use the Bit Mat tracer in Aspire. the down size is it wont work well if the picture does not have stark edges, and it creates a horrifically large number of Nodes... slows down design and carving time.
kp91 likes this.
Man with out Vision shall perish..women too!
Find more of our stuff on Etsy
https://www.etsy.com/shop/CreekWillo...platform-mcnav
Scottart is offline
post #14 of 18 (permalink) Old 02-20-2017, 11:41 AM Thread Starter
Scottart's Avatar
First Name: Scott
Originally Posted by honesttjohn View Post
Hooooo da thunk?
Another better than good one. Other than the usual outstanding paint job, that one could just weather naturally or do you have to put spar on it up there? Wouldn't even think of using stain of any kind unless it's different shades for the log and bird only. One of a kind for somebody to take home. Room to carve something with Alaska and a date if a tourist gets it.
Did you undercut the log too, or just the bird?? Never thought of doing that. But ceativity ain't one of my strong points, either.
undercutting on the bottom of almost any component will add depth and shadow. The photo i showed is directly under single light source... which helps the eye better see Values, and depth..
Many painters will do what they call a ReMarque, painting on a print. it adds value to collector prints. I like to touch all my CNC work with some carving tools. mostly to do what I can't make the CNC do... that being, carve the underside or around an edge.
honesttjohn likes this.
Scottart is offline
post #15 of 18 (permalink) Old 02-20-2017, 11:43 AM Thread Starter
Scottart's Avatar
First Name: Scott
I had not used it that way Mike.. a grand Idea.... that might get stolen..
Scottart is offline
post #16 of 18 (permalink) Old 02-20-2017, 12:14 PM
JFPNCM's Avatar
First Name: Jon
Superb piece.
Jon
JFPNCM is offline
post #17 of 18 (permalink) Old 02-20-2017, 10:27 PM
That is a real beauty! Much better than nice.
You mentioned cottonwood. I didn't know you could use it. We consider it a trash tree, more like a bush really. How does it work out
DesertRatTom is online now
post #18 of 18 (permalink) Old 02-20-2017, 11:52 PM Thread Starter
Scottart's Avatar
First Name: Scott
yes, it is rather trashy, i have done many test carvings out of it and a few benches. but it does not hold detail, has little physical strength.. but I can get 35 " wide slabs 3" thick.. I will post a picture some time.
It is still good for Chainsaw carving, and I sometimes use it for larger pieces. It dies standing up on the river near here. so drys completely ..
Scottart is offline
Laminating Cedar Fence Pickets Frankj3 Sign Making 28 04-11-2016 11:09 AM
How do i line a cedar chest? Jerry Bowen Tools and Woodworking 10 10-22-2012 05:54 PM
Working with pressure-treated cedar nematode Tools and Woodworking 18 04-23-2012 06:32 PM
Cedar Bullet mark81253 Woodturning and Lathes 9 02-20-2012 09:54 PM
Cedar Pergola TRN_Diesel DIY and Renovation 11 06-11-2010 08:49 AM
