I need to make a Chinese Checker board with 121 cove depressions for marbles.
I have a dxf file of the array, but the positions are marked as very small circles, and not points. For some reason this is leading to oval depressions instead of round ones. I do not have my own CNC machine, but a friend who has one is running tests for me using a cove bit.
Can any one point me to a dxf file where the positions are marked as points, not circles, or perhaps suggest other solutions.
Help on this would be greatly appreciated. Rob.
Thanks Doug - I got my original dxf file from the Shark Forum link.
The ovals are all aligned the same, so I will investigate the backlash suggestion. Won't get another stab at it until the weekend.
Cove bits don't plunge well as the center only spins in place. If the cove bit following a true circle is producing ovals then there must be play in the machine that lets the bit deflect while going around the circle.
Depending on which software is being used, some prefer and can use small circles rather than points (easier to see) as centers for a drilling toolpath. I use VCarve Pro/Aspire and it has that feature (drilling toolpath). In fact I'm not even sure the software can make just a point.
Just to close this matter, the culprit was my dxf file.
Magnification revealed that the small circles were anything but round.
I re-created the array in Sketchup using the smallest circles possible in the program, then exported to a dxf file via a plug-in.
I will finish off this thread with a pic of the final board in a few days time.
Thanks once more for helping me to grow my understanding.
Rob
Steve - my original file was not produced in Sketchup, but was created from a bitmap file converted to dxf by Inkscape. Pixelation on the small circles caused Inkscape to draw very rough slightly oviate circles, creating a "wobly" path for the CNC.
The file I created in Sketchup gave absolutely perfect circles. You don't have to export from an angled view, just go to top view and change camera to parallel projection. The circles are the smallest diam. that Sketchup can produce (1/2 mm), and should serve the purpose just fine, as the next best thing to a point for the cove bit.
Thank you for the dxf file, but I do not require the large circles and lines, just the points, as if a hole will be drilled at each point. I suppose what I really need is a program that defines precise location of holes. The points you have added would serve that purpose, but not with the lines.
But my Sketchup originated file looks like it will do the job just fine.
Thanks again for your input.
Related Threads
747K posts
128.1K members
Since 2004
