Honest John commented on the foam he uses a while back, but I can't really find it. So, what foam brands do people use and recommend? Also, which would you never use again?
And, what are other alternatives to foam, ply or real wood for 3D carving?
I need to machine a 3D model at a size that makes real wood not as practical.
I have used HDU Precision Foam which is available is cut sheet sizes from InterStateHDU. The 15# board I used is available in .75, 1, 1.5, and 2 inch thickness and the following sizes in inches: 12 x 12, 12 x 24, 12 x 36, 12 x 48, 24 x 24, 24 36 and 24 x 48. They are packaged well to protect during shipping. I like it and will definitely use it again. I cuts easily with crisp edges.
I got some 48 x 48 pieces of 3/4 and 1" Corafoam here. Didn't even know there was a foam place by me. Alpine will deliver a full sheet cut however you want it for, I believe, around $15.
Honest John,
I know very little about the CNC, just enough to get me into trouble. Question, do use the CNC To cut signs and such in the foam? Are you using the foam in some other way. What type or kind of bit do you use when cutting foam pieces?
You can use foam to cut or carve most anything. I"m partial to Corafoam. It comes in sheets up to 4 inches thick. It doesn't bend, warp, rot, or anything else. Using 100% acrylic paint you can prime it and paint it - hang it outside , and you shouldn't have to touch it for 8 to 10 years or better. Most of your newer "carved" business signs are made of this type of material- not wood. You can usually cut everything in one pass. No roughing pass is usually needed. Plus, there's virtually no waste, since there are no knots or imperfections. I've pocket cut letters less than a 1/16" with no chipping. I just use my regular bits. They last forever cutting this stuff.
You can use foam to cut or carve most anything. ... Most of your newer "carved" business signs are made of this type of material- not wood. You can usually cut everything in one pass. No roughing pass is usually needed. Plus, there's virtually no waste, since there are no knots or imperfections. I've pocket cut letters less than a 1/16" with no chipping. I just use my regular bits. They last forever cutting this stuff.
Wide signs though maybe 3'+ either direction may need internal support
of MDO ply or a metal frame within thats usually pocketed behind or "encapsulated"
for a double sider. No pun intended, the signs will float too.
My "BEEF" with HDU is.... the damn dust is gritty and clings to me cup of coffee.
Piss someone off and sprinkle it on their sweaty neck.... :wink:
Paint with Fuji Mini-Mite 4/5 (Q costlier and optional) for a nice finish
Steve,
Email Brad at Duna and get a sample sent to you and see how you like it. I bought a bunch from Pioneer in Pittsburgh and the shipping was $175. Now Alpine has it and they run around our area once or twice a week. Last time I talked to Rob shipping to Rochester was something like $12 or $15. It's some good stuff.
Plain old 15" density - made before they even started promoting it to the sign and carving industry. Rob at Alpine or Brad right at Duna can give more info. I know they now promote the use for signs and carving, since it has become so popular for this use. This stuff wasn't developed for that - - it is used mainly in the petro chemical industry. There's a plant in Ludington that just turns this stuff out.
The product for signs is Corafoam U 150. That is 15lb cu/ft.
I hope you get better service from Duna than I did. I called and requested to speak to someone about sign foam and was given the cell number to their outside sales lady.
I called with no answer 3 times and left a detailed message concerning my product needs. Never a single call back.
I travel to the Houston area from time to time so I will pop in on them and speak in person.
Yesterday (Sunday) I sent an email inquiry to Corafoam Duna requesting a sample. I used the link on their website for requesting samples.
This morning at 9:30am, I got a call from their rep. She asked a few questions and said they would send samples of the 15 & 20# foam. And invited me to come take a tour of their plant in Baytown! I only live about 20ish miles or so from their plant so I just might do that. And...there is a distributor in Houston. :surprise::smile:
Related Threads
747K posts
128.1K members
Since 2004
