Thanks, Gerard! I don't see any wasted wood. I used a 1/8" bit, spaced the splines close together, and will keep the leftover pieces for future projects - inlay, splines, banding, etc.
David those CNC machines are so neat. I may be wrong but I think you could do the same thing with a template and router with an inlay kit. For those of us who don't have a CNC machine we could act like we did. :wink:
'David, I really enjoyed watching the video, great jobs, both of making the video and doing the project. Experimenting and learning from experimenting is the best part of woodworking for me, or least it has been. I suppose that once a person becomes proficient in knowing most of the moves that the learning will not continue to be as interesting.
Would you mind telling me how you were able to post your video on the forum as you did?
I have done a lot of video production work but don't know how to do what you and others have done in regard to the forum.
Thanks, Jerry! I agree, this wasn't anything new but represents the first time I've done anything like it so I shot the video. I'll be doing more of these but probably won't even take a photo - won't be new stuff.
As for posting video, this particular forum makes it easy if you're posting a YouTube link. All you do is paste the full URL in this window and the forum software does the rest. Some forums make it more difficult but this one is easy.
Beautiful work David, as usual. Did you consider any other shapes, such as a bow tie as often used to control splits in large slab tables, or something a little more ornamental? Based on the location of the rabbet, I am assuming you put them on the back side, and did not make a thru cut.
I am planning some furniture builds soon, and was planning on using my CNC for cutting some pockets for loose tenons (I have a fixture on one end to hold stock vertically or at angles), but I like this concept. I may adapt it, and actually feature the “tenon”, perhaps in a contrasting wood.
Thanks for sharing your idea - hope you don’t mind if I adopt it!
Thanks, Richard! I did consider other shapes but in the end decided to keep it simple. This is a display case and the door will rarely be opened. Yes, they are on the back side. Adopt away!
One thing that it took me awhile to get used to is that when using a CNC to do a job you could have done on some other tool, there is room for improvements that would have been impossible or very difficult to do on the previous tool.
I helped a student make splines for a very similar project, and just to add a little more locking strength I changed the straight spline to a dovetailed spline. You just have to make sure the shape has both inside and outside radiused corners to permit the bit you use to cut both pockets and splines for an exact fit. Once installed your miter can't pull apart even if the glue fails.
An impressive way to do it. I don't have a CNC, so I need to resort to other methods.
When I want splines I usually want them very thick, like just one saw kerf thick. I found the best way for me was to use a tenon jig on my table saw and adjust it so that I got a one blade thickness spline off of each side of a board that's placed on end in the tenon jig. I make a cut, turn the board over and make the second spline on the opposite surface to the board, Then swap ends of the board and make two more splines. Then I take the board to my miter saw and with a stop set up to make the splines the correct width, I chop them off of both ends to the board. Then I go back to the table saw and tenon jig and make four more. Since the splines are actually the normal waste from cutting tenons, the resulting tenons made each time are cut off with the miter saw and become waste.
I've had very good results making very accurate thickness cross grain splines that are just one saw blade thickness thick this way. My latest were 0.185" thick to use in 0.187" saw kerfs and made from mahogany..
Related Threads
747K posts
128.1K members
Since 2004
