I don't post many projects and I normally don't take too many pictures of process, just the final pictures. I do have a gallery here where I update final pics of an "inlay a day"(or close to that).
Here is a 3D bas relief Cross I made for my Father a couple years ago. I didn't use my larger machines, just a little Zenbot and DeWalt 611 Router. These little Zenbots CNC machines are the most cost effective units for a first timer. I have tested them extensively. I have run 2 of them for over 4 years, 8 hours a day. So if someone wants to get in CNC and buy a first time ready made you won't get a machine for less money that will work and be reliable. Again, that's four years, 8 hours a day and not a single failure. And since I purchased my units Zenbot has made their machines much more beefy. I initially thought they would be throw away machines because they use some plastic, but after a couple years I ended up selling my Probotix machine. Although the Probotix is technically a nicer machine no doubt, it just didn't make my parts any different and at a much higher cost.
The material for the Cross is a good quality African Mahogany(some isn't) 2" thick. The Cross is a bit less than 24" long. I probably should of carved one more time with a smaller bit for more definition, but I was pressed for time and getting on plane and needed to get it out of the machine and wrapped before I left. It still looks great though and I was happy with it.
There is a Seal coat no wax shellac on it and that's all.
