I just got my new Probotix Nebula delivered today ... but that is a story for another day. When I'm not exhausted.
Worked all day to get the machine up, and I'm up against a wiring problem. The diagram calls for a black ground wire to the machine frame ... and no such wire *is identified.*
Three cables are in the harness that are not used:
1. A yellow plug for to run a router; I'm using an air cooled spindle, so that's extra.
2. A parallel plug with no known function; it's not used in any diagram that I received.
3. There's a twisted black cable with a spade connector on it that I *think* might be the ground wire, but it's unlabeled and I hesitate to just plug it in without knowing what I'm doing.
And I certainly don't know what I'm doing with this CNC!
Big stories to come, of course, but if anyone knows their way around this grounding ignorance of mine, then I can actually turn the unit on.
Help!
Help!
