I bought a set of digital (PDF) plans for a rocking horse from ToyMakingPlans.com and thought I would attempt to create vector paths in V Carve to use with my cnc. Some of the parts in the in the 60 page document cover multiple letter-sized pages that you must print out and tape together to have a full size paper pattern.
I imported one of the PDF pages into V Carve to see how accurately I could trace the outlines to create vectors. I was pleasantly surprised to find that the PDF page drawings imported directly as vectors and that the entire vector for the part was there even though only a portion of it was showing on the page. No auto or manual tracing of the image required.
In no time at all I was able to import vectors for all the parts and create tool paths for cutting them out.
The first photo shows one of the plan pages and the second how the vectors from that single page imported into V Carve. You can see that the vectors for the entire part were imported. I don’t know if other PDF plans will work as well but if you are considering using your cnc to make toys, ToyMakingPlans.com has a sure winner with their downloadable plans.
