Hello,
I?ve seen and read your many posts! I am interested in getting a CNC for some wood work, plaque work, aluminum work, and glass work. I?ve narrowed it down to the following. Your advice is much appreciated.
Probotix Nebula - I?ve read the many reviews and issues with this machine. I have no problem running Linux because I?ve got a ton of PCs around the house to run Vectric. My concern is the threads I?ve been reading about the play in the x axis. Also if I were to go with this machine what add on?s would you suggest?
Romaxx WD-2 - read some great reviews and haven?t found any negatives ones besides the height of the machine capability. Only thing for me is that it?s on the smaller side. Which I could work with until deciding to upgrade obviously but looks like a great starter machine.
Cabguy 2006 CNC router on eBay/ 4x4 performance CNC router systems - read about 8 reviews on this from some calling it made by a genius to someone having issues with it in the first 6 months. Made in Canada and the seller has answered all my questions and seems to have the same level of support as the two mentioned above. Only concern is that one buyer mentioned he only uses it for light projects as he does not think it would be capable of tougher projects, now based off my needs I believe it would be suitable as it has a router option instead of spindle.
Your input with this is greatly appreciated and I look forward to reading the replies.
Also I plan to use Dewalt 618 router with the above mentioned machines unless you suggest different.
