Is it possible tu use G-code with a General I-Carver CNC machine? - Router Forums
 7Likes
post #1 of 12 (permalink) Old 01-06-2018, 10:39 AM Thread Starter
First Name: Jean
Send a message via Skype™ to JLretired
Smile Is it possible tu use G-code with a General I-Carver CNC machine?
Hi,
I am presently volunteering in a workshop that have a General I-Carver Model 40-913. Model to carve are generated using the I-Picture software. I find that this software limits what I would like to do. The software generates "carving" files having a .gee extension.
I use "Onshape" CAD software to design parts. I can also generate the G-code file (.nc extension) to manuacture these parts using the "Kiri:Moto" software (an add-on to Onshape).
Could someone tell me if I can use G-code files with the General I-Carver Model 40-913?
Thank you very much,
Jean
JLretired is offline
post #2 of 12 (permalink) Old 01-06-2018, 10:44 AM
Forum Moderator
difalkner's Avatar
First Name: David
Welcome to the forum, Jean! I'm not familiar with that so unfortunately can't answer your question. I use Fusion 360 and Mach4 and the extension I get use is *.tap. Can you search the Onshape help files to find this out... maybe someone else who can answer your question will be along shortly.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 12 (permalink) Old 01-06-2018, 11:00 AM
BalloonEngineer's Avatar
First Name: Richard
Try opening a .gee file using notepad and take a look. They may be g-code files just using the .gee extension. If so note the first few and last few lines (the setup and shutdown lines). You will need to make sure your g-code files use these same instructions. After that you may need to just rename your g-code files to match. All g-code is plain text files, no matter the extension.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #4 of 12 (permalink) Old 01-06-2018, 11:31 AM Thread Starter
First Name: Jean
Thank you very much Richard! I will try this sometime next week and will let you know of the outcome.
Have a nice weekend.
Jean
post #5 of 12 (permalink) Old 01-09-2018, 09:38 PM Thread Starter
First Name: Jean
Good evening Richard,
Following your advice I was able to control our General I-Carver CNC machine using a G-Code file. I simply changed the .nc extension of the file by a .gee extension.
Thank you very much for your guidance,
Jean
post #6 of 12 (permalink) Old 01-09-2018, 09:50 PM
First Name: Richard
Glad to hear it worked. I’m sure that this will greatly increase the versatility of the machine. Profile and vector carving can be much quicker than raster carving.
MEBCWD likes this.
post #7 of 12 (permalink) Old 01-13-2018, 01:34 PM Thread Starter
First Name: Jean
Hi Richard,
I hope that you can help me on this one. I am experiencing difficulties with the software (KIRI:MOTO) I'm presently using to generate G-code from a CAD 3D drawing made in Onshape.
Would you be aware of a good sofware (ideally free) that could generate G-code from a .dxf file?
My research made on Internet didn't help me much.
Your advice would really be appreciated.
Jean
post #8 of 12 (permalink) Old 01-13-2018, 01:46 PM
First Name: 4D
Search for "free CAM software" and you should find several possible links. Fusion 3D is (I think) free for hobbyists.
4DThinker is offline
post #9 of 12 (permalink) Old 01-13-2018, 02:23 PM Thread Starter
First Name: Jean
post #10 of 12 (permalink) Old 08-29-2018, 12:01 PM
Dan1955's Avatar
Hello Jean, PM sent.
Dan1955 is offline
DIY CNC router - Original design BalloonEngineer CNC Routing 22 09-06-2019 12:01 AM
My First CNC Machine nikonwalker CNC Routing 32 11-03-2017 01:02 PM
