Upgrade: VCarve Pro 9.5 to Aspire 9.5 - Router Forums
 2Likes
  • 1 Post By 2muchsanding
  • 1 Post By MEBCWD
post #1 of 5 (permalink) Old 09-26-2018, 09:10 AM Thread Starter
MoHawk's Avatar
First Name: Bob
Default Upgrade: VCarve Pro 9.5 to Aspire 9.5
I've used VCarve Pro for 2.5 years and feel it's time to make the leap to Aspire. I have a surgery coming up that will limit my physical activities for 3 to 6 months. With the limitations and winter months ahead, this should be a good time for me to start the learning process.
MoHawk is offline
post #2 of 5 (permalink) Old 09-27-2018, 05:35 AM
Wishing you the best on your surgery.
TenGees likes this.
2muchsanding is offline
post #3 of 5 (permalink) Old 09-27-2018, 08:00 AM
First Name: mary
good luck with the surgery and have fun working though Aspire, I still go back from time to time to refresh myself
marecat3 is online now
post #4 of 5 (permalink) Old 09-27-2018, 12:51 PM
MEBCWD's Avatar
Bob good luck with your upcoming surgery.
I have a lot of people ask me if they should upgrade from VCarve to Aspire.
These are the questions I usually ask:
Do you want to make your own models? This is time-consuming and a lot of people just buy models they want to use instead of making their own. When you make your own models your projects become unique and stand out among those that are created from purchased models.
Do you need to import more than one third-party 3D model at a time for the projects you do? VCarve Pro limits you to one third-party model per design file so you would need the upgrade to Aspire.
How often will you be sharing files with other people? Are those people using VCarve Pro or Aspire. Aspire will save files as VCarve format, however, any 3D models and toolpaths will be removed from the file so there is a limit to saving files as a VCarve format. It is interesting that when a file is saved from Aspire to a VCarve format and it contains models created in Aspire the file icon for the VCarve file will show the models but when the file is opened in VCarve there are no models for 3D toolpaths. If you open the VCarve file in Aspire the models are not there and the 3D toolpaths are missing.
If you create a 3d project in VCare it can be opened in Aspire and will contain the models and toolpaths.
I have full licenses for VCarve Pro and Aspire because I do jobs for some customers with VCare and some with Aspire. This way the customer receives a file that is compatible with their software.
Bottom line is unless you will use the extra power of Aspire then you may want to stay with VCarve Pro.
MT Stringer likes this.
MEBCWD is offline
post #5 of 5 (permalink) Old 09-27-2018, 03:46 PM Thread Starter
MoHawk's Avatar
First Name: Bob
Mike,
Thanks for the info. I have bought a few models however you second question is one of the main reason I upgraded to Aspire. I enjoy the challenge of working with this type of software. I upgraded 2 days ago but haven't used it yet. I'm trying to get all of my outside work done ahead of my back surgery. After surgery I will get started in the learning process.
Bob
MoHawk is offline
Vectric VCarve Pro V9.5 release MEBCWD CNC Routing 0 09-06-2018 11:41 AM
3D Design Project Using VCarve Pro 8.5 MEBCWD CNC Routing 5 04-27-2017 11:31 AM
Vector editing in VCarve Pro 8 bgriggs CNC Routing 6 11-07-2015 04:33 PM
Making Rounded Text with Aspire or VCarve Pro. bgriggs CNC Routing 7 07-06-2015 09:44 AM
Vcarve Pro to NCStudio RiffRaff CNC Routing 4 05-07-2014 04:57 PM
