V Carve help - Router Forums
 3Likes
  • 1 Post By 2muchsanding
  • 1 Post By MEBCWD
post #1 of 10 (permalink) Old 10-30-2018, 07:22 AM Thread Starter
Default V Carve help
Question for any and all. First off to explain, I'm trying my hand at converting a photo to a carving.
Question: How does one control the cut depth of the image in this situation. Some of the fine detail is only .010 deep or less, can hardly see anything and the max is only about .065.
No matter what I try in the tool path, like giving it a flat bottom cut depth. I ended up telling the project that the material was .032 more than it actually is. OSHA approved???
2muchsanding is offline
post #2 of 10 (permalink) Old 10-30-2018, 11:56 AM
beltramidave's Avatar
First Name: Dave
Are you using VCarve or Aspire? If using Aspire, you will "create a model from bitmap", then you can adjust the model settings in it's properties..
If using VCarve, I am not sure...
beltramidave is offline
post #3 of 10 (permalink) Old 10-31-2018, 04:43 PM
MEBCWD's Avatar
Cary can you post the picture so we can see what you are trying to do?
It really depends on what type of picture you have.
MEBCWD is offline
post #4 of 10 (permalink) Old 10-31-2018, 07:02 PM
Gaffboat's Avatar
First Name: Oliver
Are you using a V-carve toolpath or a profile toolpath? When using a v-carve tool path, the bit can only cut as deep as the outline vectors allow. It's like putting a funnel into the neck of a bottle. The v-shaped funnel can only go in so far before the funnel's sides make it wider than the opening. The vector outlines of your artwork are like the angled sides of the funnel, and the bit can only carve down until it hits the vectors. The only way to control the depth is to either make the vectors of your artwork wider or use a smaller angled bit like 45 or less.
To use a profile toolpath, your artwork will have to be single-line vectors and you can cut on the line to any depth you prefer.
Name:	Screen Shot 2018-10-31 at 7.00.19 PM.png
Gaffboat is offline
post #5 of 10 (permalink) Old 11-01-2018, 01:05 PM Thread Starter
Naa, no picture, I don't want to. lol
Using VCarve Pro 9. something.
The problem I'm having is lack of knowledge and skill in the program.
I have to tell myself, I'm a cnc newbe, remember > baby steps... But I want to do the cool stuff NOW!
No real help needed here I guess other than a knock upside the head as they say.
UglySign likes this.
post #6 of 10 (permalink) Old 11-01-2018, 02:50 PM
MEBCWD's Avatar
Is it like the first picture or the second picture?
The first picture is easy, the second picture would be a lot of work and may not be what you want to do.
MEBCWD is offline
post #7 of 10 (permalink) Old 11-01-2018, 04:50 PM Thread Starter
Yeah, the second one. More like this, one of my family members. Best I could do using photoshop cs5 but when changin to vectors it really looks bad. Maybe too much detail in the image.
post #8 of 10 (permalink) Old 11-01-2018, 05:35 PM
MEBCWD's Avatar
Actually Cary that is not too bad but I do see that most of it is very small vectors so you will have the shallow cuts unless you make the project larger.
You might try using photoshop cs5 again and fit the vectors a little looser and see what kind of results you get.
Nice looking dog by the way.
MEBCWD is offline
post #9 of 10 (permalink) Old 11-01-2018, 06:30 PM
MEBCWD's Avatar
This is a quick vector fit in Aspire (same tools in VCarve). then edit by deleting one vector and offsetting two vectors, deleting the original two to get better definition around the nose. Still needs a little tweaking but that was something I expected. The design is 85 to 90% of most jobs.
Toolpath set for flat depth of 0.06 and highlighted with black.
2muchsanding likes this.
MEBCWD is offline
post #10 of 10 (permalink) Old 11-01-2018, 08:49 PM Thread Starter
That looks great Mike. Thanks about the nice looking dog. We have 5 Australian Shepherds, had 6 up til a week ago. That was a sad day.
I see your friend beside you. Got to love em.
I'm off to work for the weekend in Ocala, FL. Then Winston-Salem, NC next weekend. Shop will have to sit for a few.
MEBCWD likes this.
30 degree V carve lettering Scottart CNC Routing 17 05-15-2017 08:09 PM
How would you carve this? hawkeye10 Sign Making 8 03-28-2016 11:55 AM
Photo Carve Post Processor? brerfox CNC Routing 3 03-13-2013 11:29 AM
Carve Wright BuddyLove9 New Member Introductions 10 02-05-2013 03:10 PM
