logic trace 2018 digitizing a clock diagram and building the project - Router Forums
 5Likes
  • 3 Post By woodman12
  • 2 Post By woodman12
post #1 of 7 (permalink) Old 10-30-2018, 02:43 PM Thread Starter
First Name: stan
Default logic trace 2018 digitizing a clock diagram and building the project
I found a small diagram on a unique clock dial and used
logic trace 2018 to digitize the diagram and enlarge it
full size
for a large clock project .
The dial was cut by a plasma operator and the wood parts were cut with the cnc
I also cut he file on a CO2 laser to show that the file is easily used
by either machine
part1 took a small diagram of a clock dial and digitized it
part 2 this is the plasma cut of the dial and cnc machining
Name:	temp assemble.jpg
marecat3, TenGees and MoHawk like this.
woodman12 is offline
post #2 of 7 (permalink) Old 10-31-2018, 07:02 AM
MoHawk's Avatar
First Name: Bob
I worked for a large investor owned electrical & gas utility company. Part of my responsibilities was to maintain the land base for our facility mapping system. I used digitizing fairly often to add new subdivisions and large industrial complexes to our system.
I can see where it would be an advantage for a lot of projects I would like to make. What is the cost for the system you use?
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4, VistaCNC M1 Pendant
MoHawk is offline
post #3 of 7 (permalink) Old 10-31-2018, 08:27 AM
First Name: mary
very nice clock
marecat3 is online now
post #4 of 7 (permalink) Old 10-31-2018, 10:44 AM
TenGees's Avatar
First Name: Paul
Looking good, Stan. The waste from your frame might make another smaller one.
TenGees is offline
post #5 of 7 (permalink) Old 10-31-2018, 11:28 AM
MoHawk's Avatar
First Name: Bob
I just looked at Logic Trace's website. It's a very nice system however beyond my price range for hobby use.
MoHawk is offline
post #6 of 7 (permalink) Old 11-01-2018, 06:50 PM Thread Starter
First Name: stan
sent you a private message
post #7 of 7 (permalink) Old 11-01-2018, 06:54 PM Thread Starter
First Name: stan
Default the clock dial project
thanks everyone for the comments, I have been using the logic trace software since 2007 and I find all this fairly easy with good results
And the cut pout piece will make another clock as its 38 in dia
