Possible Bent Shaft? - Router Forums
 1Likes
post #1 of 14 (permalink) Old 11-15-2018, 03:51 PM Thread Starter
Question Possible Bent Shaft?
oops, my apologies.
I thought I was in the CNC section when i posted this.
Last edited by landmarksign; 11-15-2018 at 04:20 PM. Reason: posted to wrong subject
landmarksign is offline
post #2 of 14 (permalink) Old 11-15-2018, 04:19 PM Thread Starter
Hello everyone
We've been having a problem for some time now with one of our servo motors not riding along the rack "nicely".
I won't go into all the details right now as I think I may have found the problem and was hoping for some feedback on my findings.
Attached is a photo of the rack.
As you can see there is an almost crescent like shape or partial circle shape on the rack.
This shape re-occurs at regular intervals along the rack.
I thought it might be how the motor was mounted to the machine...perhaps it was crooked....but if that was the case it would have a continuous line or pattern all the way along the rack.
Then I thought it might be the rack itself was out of wack...but if that was the case the patterns would not be exactly the same at regular intervals.
My final thought is this....the shaft that connects the motor to the gear (the gear that rides along the rack)...the shaft is bent just slightly.
I'm thinking this would cause the gear to connect perfectly with the rack, then at an angle, then perfectly, then at an angle....thus causing the pattern we see in the photo.
So I'm wondering...do you think I'm right or is there something else I'm missing?
Any feedback wound be great.
Ryan
post #3 of 14 (permalink) Old 11-15-2018, 04:40 PM
I moved it to the CNC forum for you.
post #4 of 14 (permalink) Old 11-15-2018, 06:03 PM
BalloonEngineer's Avatar
First Name: Richard
I think you are probably correct. Does the recurrence match up with the diameter of the pinion (same number of teeth apart as on pinion)?
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #5 of 14 (permalink) Old 11-15-2018, 06:14 PM
This is getting confusing...there are now two threads with the same title(?).
DaninVan is online now
post #6 of 14 (permalink) Old 11-15-2018, 06:23 PM Thread Starter
Yes...it appears to be one complete rotation of the gear.
post #7 of 14 (permalink) Old 11-15-2018, 08:34 PM
John deleted one of them.
post #8 of 14 (permalink) Old 11-16-2018, 11:52 AM
MEBCWD's Avatar
One other thing to check would be where the drive gear connects to the shaft, it might be shifted so it is not consistently square on the shaft. The shaft or inside of the gear may be worn.
I think I would pull the drive motor so it is free of the rack and the drive gear is clearly visible. Then run the motor at a very slow feed rate so you can view the gear and see if you notice any variance in the operation. If you see that there is a problem then you could pull the drive gear and repeat the slow feed rate test to see if it is indeed a bent shaft.
MEBCWD is online now
post #9 of 14 (permalink) Old 11-16-2018, 01:38 PM Thread Starter
Excellent idea Mike (MEBCWD)
I'll give that a check
MEBCWD likes this.
post #10 of 14 (permalink) Old 11-19-2018, 10:45 AM Thread Starter
Mike (MEBCWD)
I was talking with a few people over the weekend about all this. One person expressed concern that if I disengage the motor from the rack to watch it run, that it will become out of sync with the other motor.
The reason, our gantry runs along the Y-axis and is driven on either side by servos. Y1 and Y2.
So they're saying in order to watch Y2 (the problem servo/gear) then I will have to disengage it from the rack but keep it connected to the controller.
Y1 would only be disconnected from the controller but not disengaged from the rack (because it's running perfectly along the rack right now).
This person seems to think doing this will cause the two motors to become out of sync. with the controller because Y2 is moving and Y1 is not.
I have no idea. Does this make sense? Would this happen or are they wrong?
Ryan
longer router shaft philr Table-mounted Routing 15 12-05-2013 06:35 PM
Repairing Older Craftsman Shaft Locks MEBCWD Woodworking Articles 0 03-08-2012 08:55 PM
1/2" dovetail bit with a 1/2" shaft Tom M Guide Bushings and Templates 9 04-08-2010 04:37 AM
Bent my collet nurumkin General Routing 6 06-27-2008 01:50 AM
Machining flats on band saw shaft Kristin D Tools and Woodworking 2 12-18-2007 01:34 PM
