T8 CNC halts when starting carve - Router Forums
 2Likes
  • 1 Post By difalkner
  • 1 Post By 4DThinker
post #1 of 5 (permalink) Old 11-16-2018, 02:38 PM Thread Starter
Default T8 CNC halts when starting carve
Hi,
I am having issues with my T8 CNC from Gearbest. I can manually control using grbl controller including starting spindle and manually moving XYZ. Using Easel however I can setup the machine and it will start spindle but hitting Carve button, within moving a few mm it all stops. Exporting gcode and sending from grbl controller does the same.
Any suggestions? Connection seems temperamental too.
scubastu is offline
post #2 of 5 (permalink) Old 11-16-2018, 02:50 PM
difalkner's Avatar
First Name: David
Welcome to the forum! When you get a minute complete your profile with first name and location.
I'm not familiar with that setup but maybe one of our other CNC guys will be along shortly to assist. By 'connection seems temperamental' do you have specifics?
David
RainMan 2.0 likes this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #3 of 5 (permalink) Old 11-16-2018, 06:48 PM
First Name: 4D
On the CNCs I oversee, the things that stop a cut in progress include hitting a limit switch, or the e-stop, or the stop/pause buttons in the control software.
I'd check your limit switches for sensitivity, as in sudden vibration setting them off.
4D
4DThinker is offline
post #4 of 5 (permalink) Old 11-17-2018, 03:28 PM
MEBCWD's Avatar
Welcome to the Router Forums.
Are you using the correct post processor for your machine? If the post processor is wrong then it could be compiling bad gcode for that CNC.
Almost sounds like your file just contains the end shutdown codes and no actual machining moves. You should be able to view the gcode in a word processing software, I use notepad, to see if there are machining commands or just code that shuts down the spindle and ends the program.
MEBCWD is online now
post #5 of 5 (permalink) Old 11-19-2018, 03:35 AM Thread Starter
The basic setup does not have any endstops, so won't be that. As I said, I can manually control with no issues, so it does seem to be related to streaming the gcode.
When I say connection temperamental, I can click connect on grbl controller a few times before it connects and with Easel it can take a few attempts to see the Arduino connected.
As far as streaming gcode, sending via grbl controller I see several G1 commands sent but of course it does not complete these as it just halts (with the need to power cycle the Arduino).
scubastu is offline
starting a new CNC build Scottart CNC Routing 55 04-23-2015 10:42 AM
needing advice re starting to work w cnc drdoree CNC Routing 2 12-04-2008 07:51 PM
