Probotix CNCs, Square and Plumb - Router Forums
 39Likes
post #1 of 57 (permalink) Old 11-28-2018, 07:02 PM Thread Starter
First Name: 4D
Default Probotix CNCs, Square and Plumb
Don't take this the wrong way.... I love the CNCs made by Probotix. We have a Meteor where I work though which has always been reliable... except when precision of detail alignment or dimension has been a critical factor.
I've lately been perplexed more than usual on why joinery cuts on my vertical clamping jig have been misaligned. Over the Thanksgiving break (9 days when no students were on campus) I decided to get to the bottom of the mystery.
With squares and precision measuring rules I went at this old Meteor. My findings surprised me, but do explain why so often over the last several years I've been dissatisfied by the results of a cut.
1. The Z axis assembly was not square to the frame or X/Y travel plane. Tilted back roughly 2 degrees.
2. The gantry wasn't parallel to the front/back frame members. Approx. 1/16" back on the right side compared to the left side.
The gantry alignment is set when homing. Limit switches on the right and left hit a triangular bracket screwed to the bottom of the side frame members. In this meteor the bracket on the right was 1/16" farther back than the one on the left. A relatively easy fix, but also should have been easy to set right at the factory.
The only way I can see to square the Z axis assembly is to rotate the gantry beam. Two bolts on each side hold the beam to the vertical side plates. These bolts go through holes in the side plates with no obvious slop in the fit. The solution I see is to remove the two front bolts, ream out the holes they went through, crank the whole beam/Z axis forward until plumb then insert and tighten those two bolts.
I also have a Meteor in my home shop, and it does not suffer the same flaws this work machine does. My Z axis is plumb. My gantry runs parallel to my front frame rail.
My point here is to check any new machine for plumb and square. In most cases flaws found can be corrected, and the accuracy of your work will increase.
4D
artman60 likes this.
4DThinker is offline
post #2 of 57 (permalink) Old 11-28-2018, 07:35 PM
RainMan 2.0's Avatar
Is there a chance the gantry amd machine got tweaked a little as a student had the router forced against a piece of wood or something, putting to much strain on the gantry as it was trying to move ?
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 57 (permalink) Old 11-28-2018, 08:27 PM Thread Starter
First Name: 4D
Our college went through a remodel that took essentially 3 years. The CNCs went through 4 moves as we were first kicked out of our original shop are so asbestos was removed and that area was turned into a large lecture room. We moved into a basement area in the old building first. Then a move to a temporary wearhouse while we waited for a temporary metal shop building to be erected near the temporary classroom building, then finally back into our new shop space. It is quite possible the Probotix CNCs were lifted by a crane using straps around the gantry which may have twisted the gantry. I personally didn't witness how they were moved any of the 4 times.
I've had the Z axis come down on immovable clamps a few times, which certainly puts unusual forces on the Z axis assembly and gantry. On inspection though I can't see any way things could have been rotated or twisted to a new position and stayed there, as I can't see any bent/damaged parts in the assembly. There is also no apparent way to adjust the rotation of the Z assembly around the beam, or the rotation of the beam itself relative to the side brackets.
4D
post #4 of 57 (permalink) Old 11-28-2018, 09:51 PM
difalkner's Avatar
First Name: David
I know you're glad to have it all lined up and like it should be.
Our Saturn gantry was out of square by about 1/8". Someone suggested I use homing to square the gantry but I would never want to do that. I'd rather have the gantry mechanically square than to force it square with electronics. And the Saturn is so rigid I doubt it could even be pulled square by the electronics. So now it's square, the gantry glides easily along the linear rails, and it cuts as it should. But it was out for the first year I ran it because I didn't realize it was out. When I fixed it all sorts of things I cut in the past began working much, much better.
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #5 of 57 (permalink) Old 11-29-2018, 01:25 PM
MEBCWD's Avatar
It is a good idea to check the alignment of your machine at least every 6 months just to make sure something hasn't changed. Just a little wear in parts will affect the alignment and quality of projects. It also lets you know when parts are failing before something major happens.
In the last year I have been getting questions on how to align the Y axis to the X axis on the Next Wave Automation CNC Shark machines. They should be aligned before they leave the factory as far as I'm concerned. When I tell them what they have to go through a couple have said they contacted Next Wave Automation customer service about the problem and they told them the same thing about aligning the machine. They were hoping there would be an easy fix but you have to remove the bed so you can get to the Y axis mount to the gantry, make adjustments then reinstall the bed and recheck alignment. Then repeat if it is still off a little.
I have considered making aftermarket upgrade kits that would allow you to make easier adjustments for aligning their CNC's but I'm trying to get away from their machines and problems just like this.
I do maintenance calls on their machines and this is one problem I will not address, too involved and time-consuming to quote a price because of what you have to do to re-align and check to make sure everything is correct.
difalkner and artman60 like this.
MEBCWD is online now
post #6 of 57 (permalink) Old 11-30-2018, 01:08 PM
Pro4824's Avatar
First Name: Joe
I bolted mine together, wired it up and started cutting. I either got lucky or my old eyes are too bad to see the misalignment issues. Someday I will run the cncrp alignment tests and adjust if necessary but for now I'm pretty happy being lucky or blind. 🙂
Pro4824 is offline
post #7 of 57 (permalink) Old 12-01-2018, 07:30 PM Thread Starter
First Name: 4D
We have an old NextWave Automation Shark HD in the same room as our Nebula and Meteor from Probotix. It was our first CNC, and was heavily used until the Meteor showed up. The plastic Z axis design of the Shark has so much flex that I've essentially stopped using that machine. We just ordered a Comet from Probotix (10% off sale right now) to take its place, and the Shark will be sold. My little CNC room will now be a Probotix-only room. As they've raised and stiffened the gantry of their designs, the little Comet should now do all that the Shark was used for (extra Z height) and with my angle jig in it should do all the complicated joinery I cut as well. I'll mount it on a taller base to handle the vertical joinery cuts on long(er) stretchers and furniture panels.
The Comet will be thoroughly inspected for square and plumb once it arrives.
4D
difalkner and MEBCWD like this.
post #8 of 57 (permalink) Old 01-23-2019, 07:33 PM Thread Starter
First Name: 4D
Today we received our new Probotix Comet. Uncrated, set up temporary on a workbench to mount the Z axis stepper and install the Y axis limit switches. A quick check of the Z axis shows it isn't 90 degrees to the bed. It appears the cantilevered weight has racked the whole gantry beam a couple of degrees forward.
We aren't quite sure how to remedy this. It was freezing cold today and the CNC parts were icy cold, so I'm going to let it acclimate to the warm shop overnight before final judgement and photos to send to Probotix. It may be possible that the bitter cold "shrank" the gantry risers which caused them to twist a bit based on how they are mounted/restricted by bearings and beam.
I'll admit I do like the improvements they've done to stiffen up the gantry/Z axis. The added Z travel will come in very handy.
4D
MEBCWD likes this.
post #9 of 57 (permalink) Old 01-23-2019, 10:16 PM
difalkner's Avatar
First Name: David
You are going to post photos, right?
David
MEBCWD and RainMan 2.0 like this.
David
Romans 3:23
post #10 of 57 (permalink) Old 01-23-2019, 10:21 PM
Right now Probotix has a 4 day sale starting --- 20% off.
4DThinker likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
