chinese 3040 wood router - Router Forums
 6Likes
post #1 of 12 (permalink) Old 12-09-2018, 12:59 PM Thread Starter
First Name: William
Default chinese 3040 wood router
Hi i bought a chinese 3040 3 axis wood router new last february it came with mach 3 which i installed its connected to a desktop computer running windows xp by a usb port on the pc to a usb b connection into the controller box i can work mach 3 using the keyboard but i have yet to get any of the axis motors to move at all the diagnostics look ok ( no lights ) was wondering if anyone could help me out
wulliepie1 is offline
post #2 of 12 (permalink) Old 12-09-2018, 03:42 PM
Welcome to the forum William, I don't know anything about CNC,someone will be along shortly to help you.
Maybe you have to learn Chinese. (just kidding).
TenGees and RainMan 2.0 like this.
Herb Stoops is online now
post #3 of 12 (permalink) Old 12-09-2018, 06:58 PM
BalloonEngineer's Avatar
First Name: Richard
Originally Posted by wulliepie1 View Post
Hi i bought a chinese 3040 3 axis wood router new last february it came with mach 3 which i installed its connected to a desktop computer running windows xp...
You may need to configure some settings in Mach3. It has quite a few settings (what signal is on what pin, how many ďstepsĒ per inch on each axis, etc.). You should go through all of the tabs and menu items and take screen grabs of what is there right now before you change anything.
I have yet to hear of any Chinese CNC to come with a legitimate, licensed, copy of Mach3 instead of an old demo or hacked copy. So you will likely need to buy a license, and download the current version from Newfangled Solutions. https://www.machsupport.com/. This is where you can also download manuals and configuration guide for Mach3.
You need to look if there was an XML configuration file that came with you machine. This file contains all the settings Mach needs to talk to your CNC, and will make configuring Mach much easier (it may be preinstalled into whatever version of mach3 came with the machine, which is why I suggested you do screen grabs first!). The newfangled website has good instruction of how and where to install the XML file. Use that to see if one was preinstalled into the version you got with machine. There also may be some plugins (.dll files) to talk to the motion controller, if it came with just an usb to parallel converter, that wonít work, so it must use a usb motion controller.
If there is no xml file, try to contact seller and ask them to send it to you, otherwise you are in for a tough slog configuring it manually.
Richard
MEBCWD and Herb Stoops like this.
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #4 of 12 (permalink) Old 12-09-2018, 07:35 PM
Thanks for the heads up. I think the lesson here is get licensed software and proven equipment. Every time I try to take a tool-related shortcut, I can look forward to disappointment. BTW, as good as XP was, it is now outdated and not all software will run correctly on it. So I'd likely buy new software and upgrade to 7, or possibly Win. 10. After using 10 for awhile on a separate laptop, I don't dislike it. It's just annoying that the Micro$ofters changed names and force updates while you wait for your computer to become available again. I don't do CNC, BTW, this is just general PC experience.
post #5 of 12 (permalink) Old 12-09-2018, 10:49 PM
RainMan 2.0's Avatar
You mean to tell me that you bought a Chinese cnc and there’s no support?
This is unacceptable!
marter1229 likes this.
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 12 (permalink) Old 12-10-2018, 01:04 PM
MEBCWD's Avatar
As Richard pointed out you need to see if they have configuration files for that machine. Check the software and make sure it is a licensed copy and up to date. Also as he pointed out the controller software and hardware needs to be USB compatible because Mach 3 usually runs from a parallel port and would need an upgrade like Smooth Stepper and ethernet port if not running straight Mach 3.
I think you will find customer support is lacking or non-existent.
MEBCWD is offline
post #7 of 12 (permalink) Old 12-10-2018, 02:33 PM
GerryAttrick's Avatar
Country: New Zealand
First Name: Alan
You might like to try on the FB group CNC FOR BEGINNERS. They are a very helpful group and members there have many brands of CNC including the Chinese clones
I am not a fan of FB but have made an exception for this group and a machine specific one for my Shapeoko3
GerryAttrick is offline
post #8 of 12 (permalink) Old 12-12-2018, 09:33 PM
Lots of people have reported problems with the bogus copy of Mach3. I see you are running XP so I wonder if part of the problem is driver related. You might want to try a more modern computer. I considered buying a similar machine but ended up getting one that supports GRBL. I use T2Laser for the software. Inexpensive, easy to use, outstanding support, and works with both my hobby CNC and my laser etcher. Not as powerful as high-end software but good enough for what I do.
Mobius48 is offline
post #9 of 12 (permalink) Old 12-12-2018, 10:09 PM
First Name: Denis
Hi, I've been using Mach 3 with a CNC Mill for more than 10 years, and having looked at the specs of your CNC Router it would appear that you only have it connected to the computer using a USB port. As another member has already pointed out, you need to connect it to the computer using a Parallel Port, unless you use a Smooth-Stepper, or similar adaptor, which would allow a USB connection from the Controller to the Computer. The DRO's (Digital Read Outs) in Mach 3 will show movement on all axises regardless of whether the controller is connected to the computer or not! Regarding the use of XP, I used XP to run my CNC Mill for about 8 years without any issues, so don't feel obliged to update the Operating System of your computer, it is not the issue. The only reason I upgraded from XP to Windows 7 was so that all my computers, I have 7, were using the same OS. The real issue is the Parallel Port. You may be aware that computers are no longer supplied with Parallel Ports, so, if you upgrade your computer you would have no option but to purchase a USB adaptor like Smooth Stepper. There are cheaper versions than Smooth Stepper available from China, and a search on Aliexpress or EBay will show you many. All the best with your Router. Denis from Downunder!
Denisjm is offline
post #10 of 12 (permalink) Old 12-12-2018, 10:35 PM
First Name: Denis
Denis again. Here is a photo of the CNC Mill I designed and made about 4 years ago. I previously had a Mill I made from plans. It was made out of MDF, not aluminium, which this one is. I use it for various operations such as cutting mortises for the work I do, but its uses are endless, and limited only by your imagination! The second photo is a prototype Jewellery Box. The top and legs were made using the CNC Mill. Most of my design work is done with V Carve, but the Jewellery Box was designed using Fusion 360, which has capabilities well beyond VCarve in my opinion. I trust the photo of the Jewellery Box whets your imagination! Denis from Downunder.
honesttjohn likes this.
Denisjm is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Router Bits vs Thickness of the wood, vs Table position fstellab Table-mounted Routing 12 03-01-2013 11:45 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
