Milling some bronze for a mantle sized replica of a monument. - Router Forums
 23Likes
post #1 of 18 (permalink) Old 12-12-2018, 07:46 PM Thread Starter
Pro4824's Avatar
First Name: Joe
This metal work is starting to get fun!!
Roughing pass.
https://youtu.be/LS0ybseid38
Finishing pass.
https://youtu.be/LJx194NY6HE
Granite cut on the wet saw.
Still needs sanding and paint...
Pro4824 is offline
post #2 of 18 (permalink) Old 12-13-2018, 08:06 AM
TenGees's Avatar
First Name: Paul
Impressive looking sign, Joe.
TenGees is offline
post #3 of 18 (permalink) Old 12-13-2018, 08:30 AM
difalkner's Avatar
First Name: David
Very nice work, indeed! I've cut aluminum one time and had the wrong bit so it didn't work out very well. How does bronze cut compared to aluminum?
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #4 of 18 (permalink) Old 12-13-2018, 09:33 AM Thread Starter
Pro4824's Avatar
First Name: Joe
Thanks!
Pro4824 is offline
post #5 of 18 (permalink) Old 12-13-2018, 09:59 AM Thread Starter
Pro4824's Avatar
First Name: Joe
David
Hi David, I've still got a lot to learn.
I broke 3 or 4 endmills on my first attempt at aluminum. It's really counterintuitive to see bits snapping at 20ipm and people saying "You're going way to slow!!" But they were right! I went up to 100ipm and no more broken bits. (Kinda like swinging an Axe vs trying to push it through the tree.)
Also, The heat is displaced with the chips so at 20ipm I was boiling the WD-40 and charring the spoil board and weakening the bit. At 100ipm no heat at all.
Aluminum vs Bronze = Pine vs Maple.
I don't use any lubricant on Bronze and it doesn't even get warm.
I was trying to think of a way to incorporate metal into a wood project, like an inlay but I think it would just end up looking like stick-on letters???
difalkner likes this.
Pro4824 is offline
post #6 of 18 (permalink) Old 12-13-2018, 11:32 AM
UglySign's Avatar
First Name: Ronnie
What about a small mister, like Fog Buster or similar?
https://www.amazon.com/Deal%E3%80%91...rds=fog+buster
Need them chips to clear w/ Alum.
Dont do an inlay... let the metal object(s) protrude the surface. 1/2 in/out
Maybe run a horizontal grain in the letters on a belt sander. They get hot fast.
Wow... too bad you couldnt flood coat it in paint... then bring to a stroke sander
to finish off the letter tops.
UglySign is online now
post #7 of 18 (permalink) Old 12-13-2018, 12:48 PM
MoHawk's Avatar
First Name: Bob
Joe, Very nice work on the bronze plaque! Thanks for providing the info on milling. I have a similar project I've wanted to tackle for 3 pet memorials and have been hesitant to try it.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4
MoHawk is online now
post #8 of 18 (permalink) Old 12-13-2018, 01:45 PM Thread Starter
Pro4824's Avatar
First Name: Joe
Yep, painting it then sanding the letter tops and bevel this afternoon, then "JB weld" it to the granite.
Stroke sander? In my shop it's a block of wood with some 220 grit wrapped around it. 🙂
Pro4824 is offline
post #9 of 18 (permalink) Old 12-13-2018, 01:59 PM Thread Starter
Pro4824's Avatar
First Name: Joe
Go for it!! I just got a cheap box of 1/8" 2 flute endmills (those 10 for $10 on Amazon) and started cutting. I'll be getting an Uglysign mister someday, but for now it's just a can of WD-40 and my air hose. 👍
I'm thinking about sinking a 90deg vbit into a piece of black granite without water and just see how that goes. We'll see!! 🙂
Pro4824 is offline
post #10 of 18 (permalink) Old 12-13-2018, 03:25 PM
Wow, very nice Joe and good info on feed rates although I'm a long way from trying metals.
2muchsanding is offline
Introduction to 3-Axis Milling phongnvt CNC Routing 0 07-07-2017 03:22 AM
Ideas: router milling jig for brass and bronze anotherBob Tools and Woodworking 3 07-06-2010 09:07 AM
