Machine noise - Router Forums
 32Likes
post #1 of 32 (permalink) Old 12-19-2018, 10:07 AM Thread Starter
Default Machine noise
Hello all,
Question for anyone but mostly for Pro4824 and HJ. I've had this clicking sound in the Z axis from day one. Is it normal? I get good clean cuts so never worried about it. I also hear what sounds like R2D2 from Star Wars.
Strange, let me know what you think.
2muchsanding is offline
post #2 of 32 (permalink) Old 12-19-2018, 10:19 AM
difalkner's Avatar
First Name: David
How well is the ballscrew lubricated on the Z axis? What about the washers and couplers - any slack in them? Can you move the ballscrew up and down with it powered off?
David
RainMan 2.0 likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 32 (permalink) Old 12-19-2018, 11:54 AM
MoHawk's Avatar
First Name: Bob
Originally Posted by 2muchsanding View Post
Hello all,
https://youtu.be/PVy1NaWYl6Y
The clicking sound is not normal. The R2D2 sound you describe is normal; it's the stepper motors working.
If all your hardware is tight on the Z axis, I would call CNCRP about the clicking.
I would also post this on https://www.cnczone.com/forums/cnc-router-parts/
Someone from CNCRP is likely to see the post and give an answer.
2muchsanding likes this.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4, VistaCNC M1 Pendant
MoHawk is offline
post #4 of 32 (permalink) Old 12-19-2018, 01:30 PM Thread Starter
Thanks Bob, I will post there and tear into the z housing to check out the ball screw. Just o over everything again. Like I said, it's been that way from day one. Oct. I think is when I got it.
It runs great...
post #5 of 32 (permalink) Old 12-19-2018, 02:10 PM
First Name: Gary
Hello all,
Wow! Something is definitely wrong. Sounds like missing bearing in the linear rail blocks and the bearings are clacking because of open space. Did you grease them?
I recall someone posting about losing bearings from the CNCRP Z axis. Sorry, but I can't recall the forum and I can't find the thread. Anyway, he did grease the bearing blocks and the bearings pushed past the end seals and dropped out of the block. When he started having problems, he opened up the axis to see what was going on, and bearings dropped out. He also had a picture of the end seal warped out of shape. I don't recall what his symptoms were along the way. Highlights the importance of proper lubrication.
I suggest you call CNCRP, get an email address, and send your video to them. They can probably help you with the diagnosis.
MEBCWD likes this.
gmedwards is offline
post #6 of 32 (permalink) Old 12-19-2018, 03:27 PM
First Name: 4D
As the click happens whenever the Z axis changes direction, a missing ball in the linear bearing block or in the ball screw seems most likely.
MEBCWD and 2muchsanding like this.
4DThinker is offline
post #7 of 32 (permalink) Old 12-19-2018, 03:42 PM
You can email CNCRP direct or talk to your salesperson and they'll send you new bearing blocks under warranty. The first ones I tried putting on lost a few ball bearings. They said not to run it and sent me 4 new ones, which I was very careful with.
The other sound is normal.
MEBCWD likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #8 of 32 (permalink) Old 12-19-2018, 04:17 PM Thread Starter
As probably with your machine the whole Z housing (ball screw, rails, and bearings) were per assembled, I just mounted it. Now that you have said that about the bearings, it sounds like maybe...
Thanks everyone!
post #9 of 32 (permalink) Old 12-19-2018, 06:13 PM Thread Starter
I opened up the front, everything looks very clean and tight, but notice the gap between the couplers.
post #10 of 32 (permalink) Old 12-19-2018, 06:26 PM
Pro4824's Avatar
First Name: Joe
Motor mounting bolts a little loose?
If you can't find the issue, your best bet is... [email protected] that guy is amazing. My X was clicking and he instantly diagnosed a R&P belt that was a little too tight.
Pro4824 is offline
What makes a good CNC router? Gundawg CNC Routing 19 11-13-2017 02:18 PM
For Sale: Weeke BP100 for sale in Salt Lake City sarahfitz0213 Woodworking Classifieds 3 07-10-2017 10:06 AM
Portable Dust Collection Cart with Noise Reduction & Dust Separator using Shop Vac pbriggs8 Project Plans and How To 5 05-18-2016 05:06 PM
My new improved homemade router milling machine. Mark55 Table-mounted Routing 16 02-01-2013 05:42 PM
