Addition to a Christmas Present - Router Forums
 41Likes
post #1 of 18 (permalink) Old 12-22-2018, 01:36 PM Thread Starter
MEBCWD's Avatar
Default Addition to a Christmas Present
Our family does a Secret Santa thing every Christmas and this year I am the Secret Santa for one of my granddaughter's boyfriend. On his list of items was a set of metal polyhedral dice for game playing so I bought the set of dice and decided to make a box to hold and protect the set of dice. The set consists of 7 different dice so I made a box with seven compartments to keep the dice from banging around and damaging the dice.
The design was done in Aspire using a purchased, modified dragon model. The model was modified to fit the bits I chose to use to cut it out to match a pocket in the top using the Inlay Toolpath . The texture on top was created with the texturing toolpath and then a model was created from the toolpath preview. Doing a 3D toolpath on the model actually saves time over the time needed to cut the texture toolpath. I was able to do some sculpting on the texture model in a few spots that need a few changes.
The box itself is made from Cherry with a textured top and I used Peruvian Walnut for the dragon head onlay/inlay. Just a rattle can lacquer finish.
kp91, JFPNCM, Barry747 and 11 others like this.
MEBCWD is online now
post #2 of 18 (permalink) Old 12-22-2018, 01:43 PM Thread Starter
MEBCWD's Avatar
Here is a picture of the dragon after being cut out to show the color before the finish was applied. Still needed to be cleaned up before use. It is laying on the board it was cut from.
kp91, Danman1957, TenGees and 3 others like this.
post #3 of 18 (permalink) Old 12-22-2018, 02:12 PM
RainMan 2.0's Avatar
Wow and holy smokes ! That looks just beautiful
Can’t get over the versatility of having a cnc router table. Just an inexhaustible assortment of ideas
MEBCWD likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 18 (permalink) Old 12-22-2018, 02:17 PM
Pro4824's Avatar
First Name: Joe
Wow, that's just Beautiful!! He's gonna love it!
I've been trying to figure out aspire texturing all week with no luck.
MEBCWD likes this.
Pro4824 is offline
post #5 of 18 (permalink) Old 12-22-2018, 02:18 PM
Pro4824's Avatar
First Name: Joe
Rick beat me to the Wow! 🙂
MEBCWD likes this.
Pro4824 is offline
post #6 of 18 (permalink) Old 12-22-2018, 03:10 PM Thread Starter
MEBCWD's Avatar
I have had Aspire since it was V2.0 so I have learned a few things about texturing using the Vectric software.
If you are using the Texturing Toolpath the results will change each time you recalculate even if you don't enter new values or change any settings. This is because of all the variables in the toolpath that are used to calculate the toolpath. If you are using VCarve then I suggest recalculating the toolpath while changing the values and variables until you are close to what you want to do, then keep recalculating without making changes to values or variables until you get the desired results. Then save that toolpath so it does not get changed somehow, like recalculating all toolpaths would do.
In Aspire I found that the Texturing Toolpath takes quite a bit of time to cut. You can run the preview of the toolpath then create a component from that preview. Then you can use the modeling and sculpting tools to modify the component to use in the project. You can change the height, add or subtract material, smooth and modify it as needed. Remember to save a copy of the model before you start making changes so you can start over if needed. You can then machine into the model for things like the pocket for the inlay on this project. I also find that most times a #3d toolpath runs in less time than the texturing toolpath by itself.
You can also create a texture model from a bitmap image, modify as needed and drop it onto the composite model to add detail to the model easily. see the attached picture
honesttjohn likes this.
post #7 of 18 (permalink) Old 12-22-2018, 05:30 PM
Pro4824's Avatar
First Name: Joe
Nothing too complicated. I'm just trying to make a date tag with what they call a leatherette texture. Still playing with the bronze.
Pro4824 is offline
post #8 of 18 (permalink) Old 12-22-2018, 08:46 PM
MoHawk's Avatar
First Name: Bob
Wow, double WOW!! He'll want your for his Secret Santa every year. I'd be happy just setting looking at the box rather than using the dice.
kp91 and MEBCWD like this.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4
MoHawk is online now
post #9 of 18 (permalink) Old 12-22-2018, 08:56 PM
ewwww...
I like that...
MEBCWD likes this.
post #10 of 18 (permalink) Old 12-22-2018, 09:56 PM
old55's Avatar
First Name: Ross
ewwww...
I like that...
Me too.
MEBCWD likes this.
Ross,
old55 is offline
Clock for Christmas Present MoHawk CNC Routing 12 12-22-2018 01:02 PM
Idea for Christmas present harrysin Lobby 15 12-15-2018 12:33 AM
Spool cabinet for wife's christmas present jaguar1201 Show N' Tell 34 12-30-2015 04:16 PM
Christmas Present BernieW Woodturning and Lathes 7 11-28-2008 11:30 PM
Late Christmas Present.... challagan Corey's Wooden Stuff 15 03-23-2008 12:23 AM
