V-carve Issues - Router Forums
 1Likes
post #1 of 11 (permalink) Old 12-30-2018, 01:56 PM Thread Starter
Default V-carve Issues
I'm having a heck of a time getting clean lines from my v carve bits. It seems like the bit is dull do to them splintering the wood but they are fairly new Amana bits. As you can see in the pictures it would take me a decade to sand.
From the pictures can you tell if my bits are dull or is my rpm's to high. I really don't know what my rpms do to its a bosch router.
Any advise and help is greatly appreciated.
whitleymw is offline
post #2 of 11 (permalink) Old 12-30-2018, 05:59 PM
Pro4824's Avatar
First Name: Joe
Wow that's pretty rough, what's your feedrate?
Pro4824 is offline
post #3 of 11 (permalink) Old 12-30-2018, 06:58 PM
UglySign's Avatar
First Name: Ronnie
N/a ... are you hogging out all w/ the V-bit?
You'll definitely dull the bit.
Hogout w/ 1/8~1/4" then go around perimeter with the vbit.
Provided you're on the same depth. You'll have less but wider tool path
and have it sanded within the day.
At first it looks like HDU.
Stay tuned more to come...
UglySign is online now
post #4 of 11 (permalink) Old 12-30-2018, 07:09 PM Thread Starter
I will give that a try thanks for the reply
post #5 of 11 (permalink) Old 12-30-2018, 10:08 PM
difalkner's Avatar
First Name: David
Welcome to the forum @whitleymw ! When you get a minute complete your profile with first name so it clears the N/a in the side panel. You can also add your location.
I cut things like that with a 90 or 60 bit and take two or three passes with the last one being about 0.005" lower than the one before it. That seems to clean out the fuzz sufficiently.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #6 of 11 (permalink) Old 12-31-2018, 11:28 AM
Pro4824's Avatar
First Name: Joe
David, do you slow your feed rate on the last pass?
Pro4824 is offline
post #7 of 11 (permalink) Old 12-31-2018, 11:33 AM
MEBCWD's Avatar
Welcome to the Router Forums.
This might be related to the wood you are using for your project. Some woods will leave a lot of areas like this to clean up, others will cut so clean you won't have much cleanup or sanding.
Softer woods tend to tear and leave fuzzies you need to deal with while harder woods cut more cleanly. Also if the wood has a higher moisture content you will get more fuzzy areas that need cleaning.
When using softer woods you can set up your toolpaths to cut close to the lines then make a final pass to help clean up the fuzzies depending how bad they are like David suggests.
Also like Ronnie says you can get cleaner pockets if you use a larger tool to clear the majority of the waste.
UglySign likes this.
MEBCWD is online now
post #8 of 11 (permalink) Old 12-31-2018, 12:47 PM
difalkner's Avatar
First Name: David
Rarely. If it is still fuzzy after dropping 0.005" then I'll make some changes but 90% of what I cut is Walnut and the rest is a blend of Maple, Cherry, Sapele and about 0.1% Pine. So 'fuzzy' doesn't really factor in with those woods but I do see it in some cross grain directions occasionally. I have found that dropping Z height zero by a few thousandths will clean up the fuzz quite nicely.
David
David
Romans 3:23
post #9 of 11 (permalink) Old 12-31-2018, 01:00 PM
UglySign's Avatar
First Name: Ronnie
Skip the Dish Bowl bit, thats good for bowls
or bottoms of boxes etc. Good for hogout w/ bit width allowance.
There are some bits out there that have a small
radius instead of sharp tips. Usually, .01~.04 give or take.
Meeting an angled side w/ rounded bit could be tricky, dunno.
Me honestly, I have not cut soft/hard wood yet.
I'm still gettin me shop org'd.
post #10 of 11 (permalink) Old 01-02-2019, 09:28 PM
First Name: Harry
I was having a terrible time using a (newish) 90 degree V bit until I watched this video youtube.com/watch?v=NugdOnwnnPY[
My 87 degree setting solved most of my problems.
htasker is offline
Reported Issues After Updates Cricket Site Help and Suggestions 12 06-23-2018 09:11 AM
Bosch 1200 are issues (from a complete amateur!) Olliema General Routing 6 02-01-2017 06:37 PM
Carve Wright BuddyLove9 New Member Introductions 10 02-05-2013 03:10 PM
RVS4000 Speed issues looking to replace Marcus556 Lobby 1 01-16-2012 04:58 PM
Recent Login Issues (11/15/2009) Mark Site Help and Suggestions 6 11-18-2009 03:21 PM
