Y axis - Router Forums
 1Likes
  • 1 Post By difalkner
post #1 of 3 (permalink) Old 01-02-2019, 04:43 AM Thread Starter
Default Y axis
Hi guys I'm at a loss here. I have a saturn 2 4x4 that I just finished building. I have a gecko 540 ESS smooth stepper usin rbe warp 9 plug in with nema 23 motors. My Y axis (I have it set using the bridge) steps off .04" with each pass around a rectangle. I have my steps per set to 1735 with a velocity of 400 and acceleration of 25. I've been beating my head against the wall for over a week now and I've thrown in the towel. Love the machine it's a brick! I just need to interact with it better.
Jason Litvak is offline
post #2 of 3 (permalink) Old 01-02-2019, 08:08 AM
difalkner's Avatar
First Name: David
Welcome to the forum, Jason! When you get a minute complete your profile with first name so it clears the N/a in the side panel. Also, adding your location helps.
We have the very first Saturn 2x4, Nate's prototype, and it is definitely built like a brick! What are you using for controller software? I use Mach4 and there's a 'Steps Wizard' for helping calibrate the motors. I believe Mach3 also has that. How did you arrive at the 1735 for your steps?
David
RainMan 2.0 likes this.
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #3 of 3 (permalink) Old 01-02-2019, 02:59 PM
MEBCWD's Avatar
Welcome to the Router Forums Jason.
You might check with Nate at Fineline Automation to see if he can supply you with configuration files for your build. That should give you a better start with your machine.
If he can't supply you with the files then you might check at https://www.cnczone.com/forums/fineline-automation/
Good luck with your build, let us know how it is going.
MEBCWD is online now
Speeding up X and Z axis velocity in LinuxCNC 4DThinker CNC Routing 5 11-18-2017 09:09 PM
4th axis, Any experience? SteveMI CNC Routing 1 02-28-2016 10:57 AM
Slaving Axis silverfox61 CNC Routing 6 06-26-2015 11:32 AM
Axis A Homing silverfox61 CNC Routing 0 06-22-2015 08:52 PM
BobCAD CAM V25 4th Axis Standard aldepoalo CNC Routing 0 09-20-2012 06:10 PM
