X axis - Router Forums
 2Likes
  • 2 Post By 4DThinker
post #1 of 7 (permalink) Old 01-27-2019, 08:55 AM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
Default X axis
Hi guys I have a problem with my x axis is only one side is turning I have swapped out the motor with one I know is working and it's still the same would the pins and ports setting have anything to do with it I'm using mach 3 thanks
daved210 is offline
post #2 of 7 (permalink) Old 01-27-2019, 11:37 AM
First Name: 4D
What brand of CNC are you using? The driver in the controller may have failed. A cable may have shorted out. If your machine uses limit switches on may have shorted out. Hard to know without knowing what kind of CNC you have.
MEBCWD and RainMan 2.0 like this.
4DThinker is offline
post #3 of 7 (permalink) Old 01-27-2019, 01:38 PM
difalkner's Avatar
First Name: David
Move the cable to one of the Y motors and see if it works there. If your machine has two Y motors then disconnect the other one while you do the test.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 7 (permalink) Old 01-28-2019, 02:36 PM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
It's a compass 1000 with profi4 controller thanks
daved210 is offline
post #5 of 7 (permalink) Old 01-28-2019, 02:37 PM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
I'll try that tomorrow thanks
daved210 is offline
post #6 of 7 (permalink) Old 01-28-2019, 08:47 PM
MEBCWD's Avatar
Sounds like your CNC is setup with your X axis running through the bed, gantry running on the X axis. From what I could see on their site you are probably running Mach 3 for your control software. You might contact them and see if they will provide configuration files for your CNC.
If you can't get files from them then here is the link to a video that explains how to slave the motors so they run together.
MEBCWD is offline
post #7 of 7 (permalink) Old 01-30-2019, 12:18 PM
kolias's Avatar
First Name: Nicolas
Is the cable connecting the controller to the PC ok? You can check it with a continuity meter to assure all 25 pins are through
Nicolas
kolias is online now
Speeding up X and Z axis velocity in LinuxCNC 4DThinker CNC Routing 5 11-18-2017 08:09 PM
4th axis, Any experience? SteveMI CNC Routing 1 02-28-2016 09:57 AM
Slaving Axis silverfox61 CNC Routing 6 06-26-2015 10:32 AM
Axis A Homing silverfox61 CNC Routing 0 06-22-2015 07:52 PM
BobCAD CAM V25 4th Axis Standard aldepoalo CNC Routing 0 09-20-2012 05:10 PM
