x y cnc laser $350. - Router Forums
 17Likes
post #1 of 11 (permalink) Old 01-31-2019, 11:11 PM Thread Starter
Scottart's Avatar
First Name: Scott
Default x y cnc laser $350.
Gents
I see several of you chatting about adding a laser to your tool bag. I have a Shark HD and pondered adding the $950 laser kit..... but frankly I just want to be able to inscribe some stuff and use it to drop my logo on the back of my carvings... instead of a hot iron.
I found the Bachin laser that gives me about a 15 x 20 footprint to print in. it took 2 hours to build and another hour to learn some basics. It is basically and 2 axis belt drive CNC laser. I have done lots of little logos and stuff. For under $400 it is a sweet, add to the tool box and I think a fine way to figure out Laser stuff.
The entire assembled thing weighs under 10 pounds, comes very well packaged with all the parts separated in a plastic box with allan head screws for assembly. I can lift it up and slide a full piece under it and away it goes. It has a simple test mode to set it up to see what area it works in. I down loaded the software in about 2 minutes. the instructions are not great, as is the support. but I am limping along and will spend more time later to figure the balance out. but for now I can laser my logo, tell a quick story on the back of a carving and burn stupid sayings on wooden spoons for my wife's gift store.
I have not figured out how to change power, other than to set it to burn slower. and changing size seems to have to be done when you set up the DXF file.. I use Aspire to create DXF files. THis thing is also in metric and I have not found out how to change it. But assume that I" in aspire is 1 MM the project display board...
Some thing for your to ponder....
bachin_d8-4050p [Bachin Maker WIKI]
Name:	Bachin laser.jpg
Name:	WCS logo card..jpg
Man with out Vision shall perish..women too!
Find more of our stuff on Etsy
https://www.etsy.com/shop/CreekWillo...platform-mcnav
Scottart is offline
post #2 of 11 (permalink) Old 02-01-2019, 07:02 AM
UglySign's Avatar
First Name: Ronnie
Uh oh.... another toy of creation in the making.
mjadams61 likes this.
UglySign is offline
post #3 of 11 (permalink) Old 02-01-2019, 07:52 AM
difalkner's Avatar
First Name: David
Looks like it does a good job, Scott. What wattage is the laser? On those samples you showed, is that one pass or did you make multiple passes?
David
MEBCWD and RainMan 2.0 like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 11 (permalink) Old 02-01-2019, 08:04 AM
First Name: mary
what soft ware is running it?
marecat3 is online now
post #5 of 11 (permalink) Old 02-02-2019, 07:32 PM
Pro4824's Avatar
First Name: Joe
Thanks for muddying the laser decision Scott!! 😉
I was all set on the ebay K40 $400 but now I'm thinking yours is better.
Pro4824 is offline
post #6 of 11 (permalink) Old 02-05-2019, 05:11 PM Thread Starter
Scottart's Avatar
First Name: Scott
it is clearly Chinese and the instructions reflect that. It is easy to get basically working, but things like power settings.... no information. it says it has adjustable power, but all I have been able to do is slow down the burn time. And it is in MM.. can not find anyway to change it to inches.
But it sure as easy to set up and fires right up.
Scottart is offline
post #7 of 11 (permalink) Old 02-05-2019, 05:22 PM
Pro4824's Avatar
First Name: Joe
I'm sure the K40 is about the same but something else to tinker with.
Here's that pic, anything along these lines but with a female fishing. Don't think there'd much of a difference 🙂
Name:	Fishing _1549408852546.jpg
Pro4824 is offline
post #8 of 11 (permalink) Old 02-08-2019, 11:12 AM Thread Starter
Scottart's Avatar
First Name: Scott
ok I will play with it this week end and let you know.
Scottart is offline
post #9 of 11 (permalink) Old 02-08-2019, 03:24 PM
MoHawk's Avatar
First Name: Bob
Does the unit create much smoke with the type of work you use it for. I would like to buy one however my workshop is in my basement and if it creates much smoke my wife would complain.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4, VistaCNC M1 Pendant
MoHawk is offline
post #10 of 11 (permalink) Old 02-08-2019, 07:38 PM
Pro4824's Avatar
First Name: Joe
Sounds great, thanks. You can add a blimp and some gears if you feel the need!! 😉
Pro4824 is offline
Creating UI for CNC Laser Engraver jmsarno CNC Routing 1 12-07-2016 06:59 AM
Noob: CNC Router vs Laser jezter6 CNC Routing 15 11-18-2016 04:26 PM
CNC router vs Laser Cutter/Engraver lpgasparotto General Routing 0 05-19-2016 09:44 PM
