Not starting where I expected it to - Router Forums
 13Likes
post #1 of 17 (permalink) Old 02-08-2019, 12:03 PM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Default Not starting where I expected it to
This is my first attempt at a program and I watched several tutorials but I'm still lost. I have set the X,Y zeros and used the touch plate for Z zero on the top of my work piece. I load the program in the pendant, and when I hit start the spindle moves about 2 inches away (Left) off the working piece on the X axis and then starts the plunge. I just stop it at that point. What am I doing wrong?? Or what am I missing in my program? I have tried several different things and every time it does the same thing. When I preview the tool path before saving, it does what it should.
I checked for offsets in the program and I could be wrong but all I see is X= 0.0 Y = 0.0 on the area where you set up tool paths. Unless there is another area that I could not find.
Does the machine have it's own set of X, Y, zeros that need to be set?
I'm running a CNC Shark HD4 with VCarve Pro 9.5
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #2 of 17 (permalink) Old 02-08-2019, 02:20 PM
kp91's Avatar
First Name: Doug
I don't have a Shark, but I have made the mistake in Vectric when setting up my start reference point once or twice, maybe go back and recheck the file and regenerate your toolpath.
just re-read your post. Yes, I have to set the X,Y and Z zeros on my machine before I cut. I don't know your interface, but mine I position the bit over the XY zero on my project piece and then zero out the machine.
OCEdesigns likes this.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 17 (permalink) Old 02-08-2019, 02:52 PM
difalkner's Avatar
First Name: David
As Doug said, Chad, check where you are setting your X and Y zero. It should be on the work piece somewhere, usually bottom left corner or center. I assume V Carve shows you where the origin is relative to the piece and that's where you should be setting zero for those axes.
Post a video if you want - landscape, please (widescreen).
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #4 of 17 (permalink) Old 02-08-2019, 03:17 PM
MoHawk's Avatar
First Name: Bob
Call Next Wave Automation, I hear they have great customer service.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4, VistaCNC M1 Pendant
MoHawk is offline
post #5 of 17 (permalink) Old 02-08-2019, 03:20 PM
BalloonEngineer's Avatar
First Name: Richard
Unless your design has a cut at x=0, y=0 the machine often does need to move somewhere to start cutting. In the simulation, is first cut about that distance from the origin (obviously over the stock)? On some machines the X axis is the long direction, on some it is across the gantry. Are you certain how your machine has the X-axis and Y-axis oriented? Is the desired X-axis of the stock oriented in the same direction?
Does the machine have a pendant or computer control? If you jog +X does it move in the direction you expect?
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #6 of 17 (permalink) Old 02-08-2019, 03:59 PM Thread Starter
OCEdesigns's Avatar
First Name: Chad
It does have the pendant. I did double check the direction and it is correct.
At first I did have the work piece oriented wrong but quickly changed that.
The simulation all looks good and there is no cut in the X zero Y zero location.
David
I will double check that. Now that you mention it I might have not changed my set point on the program to reflect the work piece X,Y, zero I established.
Thanks for all the responses! As soon as I get home I will check my programming again. If I'm still having issues I'll post up a video. Landscape of course!!
difalkner likes this.
post #7 of 17 (permalink) Old 02-08-2019, 05:46 PM
Gaffboat's Avatar
First Name: Oliver
I'll use the center of the stock for my example. Set up your V Carve file so X, Y zero is located in the center of the project and save your toolpaths. On the Shark, manually jog your tool so it is located over the center point of your stock. (I mark mine with an X). Tap the "Zero X,Y,Z" button on the pendant, followed by the "OK" button on the next screen. The pendant will return to the main screen after you do that. Your machine in now centered on the stock the same as your V Carve toolpath. Next, zero your Z height and you should be ready to cut.
Name:	1 Set Zero.jpeg
Name:	2 Set Zero.jpeg
Name:	3 Set Zero.jpeg
Gaffboat is offline
post #8 of 17 (permalink) Old 02-09-2019, 11:06 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Thanks for this!!
I think that was my problem. I did another program last night and set my VCarve file in the center like you describe. After work today I will try to run it.
post #9 of 17 (permalink) Old 02-09-2019, 12:57 PM
MRJ
When you open your job set up, you will see a box labeled: XY Datum Position. You can select your starting point there. Click center if you want to start at the center, bottom left to start there etc. I did this a couple times before I realized my error.
MRJ is offline
post #10 of 17 (permalink) Old 02-09-2019, 01:27 PM Thread Starter
OCEdesigns's Avatar
First Name: Chad
On the left side when you first start the set up is where you first make this choice right? Then on the right side when doing the tool paths it must also stay in the same position correct?
Then you set up the machine X,Y, zero on the work piece in the same position right?
If so, I am pretty sure this is where I messed up!!
And when you save the program to the USB are you using the CNCShark-USB_NewArcs_inch post processor?
Starting pin Mike Table-mounted Routing 2 11-09-2011 04:09 PM
starting to figure things out ctsooner Table-mounted Routing 10 04-12-2010 08:17 AM
starting pin jig levon Jigs and Fixtures 14 06-16-2009 05:48 AM
Just Starting............. Jeff Martin New Member Introductions 4 05-02-2009 07:55 PM
