What to do, what to do? - Router Forums
 30Likes
post #1 of 19 (permalink) Old 02-13-2019, 10:41 PM Thread Starter
gdonham1's Avatar
First Name: Guy
Default What to do, what to do?
Hi All,
I have been a woodworker for 35 years. I am an advanced amateur. I have a full woodworking shop (See my profile) and have a lot of experience at building cabinets, furniture, boxes and small items. I turn, scroll and generally what ever I want to do. I am retired and do not want to make a business but do want to sell some things.
I think I want to incorporate a cnc router into my shop. I have read all the advice about why you want a cnc and understand the big learning curve to be proficient. I was a Field Engineer for Eastman Kodak, Sun Microsystems and Oracle. I am a certified systems administrator for Solaris (UNIX) and have been through electronics school. So I have the required electrical/mechanical background for understanding, building and maintaining a cnc router kit.
My question to the group here is what is the best machine.
I am considering:
1. Openbuilds Workbee 32x50x3 work area, belt driven x&y and ball screw driven z. Around $2000.00 +
2. Shapeko XXL 33x33x5 work area, belt driven x&6 and ball screw driven z. Around $2000.00 +
3. MillRight Power Route 25x25x5 work area, all axis ball screw driven. Around $3000.00 +
There are countless others out there but from my research these seem to be the cream of the crop.
I have eliminated the xcarve due to the many bad reviews about the stability and rigidity of the system.
Can any of you give me your opinions of these or any others I should consider.
I am in no hurry to buy, in fact I have decided to have a cooling off period before making my decision to buy. I always take a long time to decide and shop before buying. I have seen many others get all excited about a thing, buy in haste and repent in leisure.
I do not have any specific projects as yet but do not want a little system. I have found it is better to go big rather than to go small, upgrade or replace later.
Thanks for your attention and opinions.
Danman1957 likes this.
gdonham1 is offline
post #2 of 19 (permalink) Old 02-13-2019, 11:49 PM
RainMan 2.0's Avatar
I’m not qualified to give you much of an answer , as I have a cnc laser but have not yet purchased my cnc router table .
But after a lot of research, I am going to purchase a pro version from cncrouterparts at some point , but I think it may be more than you require or want to budget for .
What I do like about the ones from cncrouterparts is , you can upgrade the size at some point if you find its to small .
I googled the first two you posted and didn’t like the Z height on the WorkBee . Personally , to me they look a too little light duty .
Kinda liking your third choice if I had to pick one of the three.
I like your idea of go big instead of having to replace later ,so I think some may suggest going with something in the middle like Probotix .
MEBCWD likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 19 (permalink) Old 02-14-2019, 01:25 AM
First Name: 4D
One thing to consider is if you want to do some vertical cutting for furniture joinery at any point or just stick to flat work done on a solid bed? I teach furniture design to college students. We use 3 CNCs from Probotix.com in our fabrication lab. Two are older models that area still running fine, and one was brand new in January. Despite an initial bug due to a bad cable it is now running smooth and also cutting a variety of flat and vertical/angled work.
I like their design because the open frame has nothing running beneath it, and once mounted on a base with no top I can solve many woodworking cutting challenges with creative clamping inside that perimeter frame. If you are interested I've posted several of the creative uses for mine on my blog at: 4D Furniture Thoughts
The photo attached is of our latest 25x25 version, mounted on a simple but tall base with my clamping jig inside it. The latest models from probotix have a beefier Z axis/gantry assembly that also has more Z axis clearance above the bed than their earlier models. Their CNCs come completely assembled, and need only a few cables and the Z stepper bolted down to get running. You'll have to come up with a way to hold work down though. I've installed my jig AND some MDF slats with t-track between them on my personal 25x50 Meteor from them.
4D
difalkner, MEBCWD, MoHawk and 2 others like this.
4DThinker is offline
post #4 of 19 (permalink) Old 02-14-2019, 05:28 AM
Stretch the budget and go Probotix at the very least. A CNCRP would be better if you plan on getting serious about this. The Probotix will do until you decide how heavy you want to get into it. Then decide from there. Whatever bed size you think will do, go bigger by one or two sizes. Whatever you do, get something from a USA company. Support is very important - and being able to communicate in English and get parts is vital.
difalkner, MEBCWD, MoHawk and 3 others like this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #5 of 19 (permalink) Old 02-14-2019, 06:29 AM
ger21's Avatar
First Name: Gerry
Looking at your profile, it looks like you have some high quality tools.
Imo, I think that you'll find the 3 machines you mentioned to be little more than "toys", or very lightweight hobby level machines.
I spend a lot of time on various CNC forums, and see this question a lot. The problem, is that it's nearly impossible to answer. The reason, is that the answer depends entirely on the users expectations.
There are obviously a lot of people that own those machines, and are very happy with them.
But there are probably a lot of people that bought them, and quickly moved on to something better.
Budget, of course, can play a large role.
For a serious woodworker, I'd recommend nothing less that a CNC Router Parts Pro series machine. Probably a 4x4? You can save a considerable amount of money if you can do all of the electronics yourself.
Another, similar option would be to build an extrusion based machine from scratch. A lot of people have built machines from plans at Joescnc.com over the years. What started as his "4x4 hybrid" model has evolved over the years to the current "Evolution" machine, which is very similar to the CNC Router Parts machines.
The main issue I think is that you have to spend a fair amount of time browsing his private forum to gather all the info for the Evolution machine. I think it's $100 for the plans, which grants you access to the private forum. There are lots of friendly and helpful members there.
Ger
www.cncwoodworker.com
ger21 is offline
post #6 of 19 (permalink) Old 02-14-2019, 05:06 PM
MEBCWD's Avatar
I definitely agree with Gerry about the CNC's you listed.
I also agree that it will depend on your budget.
Some of the entry model CNC's are aimed at the people with small budgets but they often lack the stability they need to cut parts accurately. They may be a good choice if you only wish to make signs and plaques that don't require tight tolerances. If you want to cut parts that fit together into an assembly then you need to stay away from those entry model machines.
There are limits to all of the machines on the market and you can get acceptable results with most of them if you stay within the limits of each machine. If the structure of the CNC is loose then you might be able to run at a slower feed rate to overcome some of that looseness. Still, your parts might be off. If it is limited in Z height then you will have to make sure you have room for materials, bit length and also remember to provide for safe Z height above your material. If you don't stay within a small Z height limit then you will probably lose your Z-Axis reading and that will cause you to carve deeper than your toolpath calls for, possibly cutting into you spoil board or worse, cutting into the structure/frame of the CNC. Some CNC's will have a limit to the weight of the spindle or router they can handle and if you exceed that limit combined with looseness in the structure can cause twisting of the gantry and very poor cut quality and accuracy. It can also limit the shank size of the bits you can use.
CNC machines are like any other tools in your shop. Cheaper tools have more limitations but can still be used if you stay within their limits. Just remember it really depends on what you expect from the machine you buy.
MEBCWD is offline
post #7 of 19 (permalink) Old 02-14-2019, 08:44 PM Thread Starter
gdonham1's Avatar
First Name: Guy
I can see the points made about buying a larger more stable semi-pro system. When I was thinking about getting into turning I had to decide if I wanted a mini lathe or get a bigger lathe from the start. When you get the mini lathe and you like turning you must sell it or eat the cost to get a bigger lathe. On the other hand if you get the mini lathe and you do not like turning then you can sell it.
My problem with turning is I liked it and got the bigger lathe.
I see some used cnc routers (hobbist) level that the turning example fits. The people bought a kit, did not know what they were doing and the system sat there collecting dust.
I do not think I will let the dust collect. So I will reconsider the larger systems.
I realize that there is a tremendous learning curve for design and implementation of the cnc router into a work flow. I have a very good electronic and mechanical back ground. I have very good computer skills and know that I can eventually master the cnc router.
As always if you think you can't, you can't. If you think you can you can!
An experienced woodworker knows how to fix mistakes, a really experienced woodworker knows when to drop the whole thing in the can and start over.
Thanks everyone for your input. It is always good to get counsel from more experienced people.
MEBCWD likes this.
gdonham1 is offline
post #8 of 19 (permalink) Old 02-14-2019, 08:50 PM
ger21's Avatar
First Name: Gerry
For some, the learning curve isn't nearly as steep as you think.
At the end of the day, it's just a router. The better you are with a router in your hands, the easier learning CNC will be. You just tell the computer what you want the router to do, and it does it for you.
BalloonEngineer and MEBCWD like this.
Ger
ger21 is offline
post #9 of 19 (permalink) Old 02-15-2019, 12:27 PM
BalloonEngineer's Avatar
First Name: Richard
One other option, given you background, is to consider a DIY machine. I spent about $2800 on mine, and consider it fairly close to the CNC Router Parts 4 x 4 one in performance and size (mine is larger at 49" x 60" cut area, and will soon be expanded to 100" long). The cost was much lower because I got a good deal on the extrusions, and put together the electronics on my own, mine are basically the same as their NEMA23 plug and play. I run Mach4 and I think CNC Router Parts are still pushing the deprecated Mach3 (hasn't been updated since 2012 - stay away on a new machine). I have an attachment similar to what @4DThinker illustrated that I can use to attach boards for vertical or compound angle cuts, many of the machines out there are not adaptable to this, and I think it is useful in furniture making. Just another option, I think the advice above is all valuable and comes from experience. Watch out though, or you will soon be advised to jump to the 10-15K machines...
Tubular latex pressure vessel configuration engineer
BalloonEngineer is offline
post #10 of 19 (permalink) Old 02-15-2019, 03:00 PM
Pro4824's Avatar
First Name: Joe
4D
Wow 4D!! That's a great looking Probotix machine!! 👍
Pro4824 is offline
