File for a 1911 - Router Forums
 33Likes
post #1 of 22 (permalink) Old 02-18-2019, 06:27 PM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Default File for a 1911
I have searched here and Google and not really finding what I'm looking for. I have a nice 1911 that I want to make a display case for. I want to hold the gun in an inlay lined with felt and also have a magazine with it. What is the best way to get the right dimensions for the inlay? I'm sure there is an easy way to get it just right without trial and error but being new to this I'm probably over thinking it! I started to do a trace of a bitmap photo but the dimensions seemed to be off as I was cleaning up the fine details I won't be needing.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #2 of 22 (permalink) Old 02-18-2019, 08:24 PM
A digital drawing pad would allow you to trace the outline wouldn't it? You'd have to tell your cut file how deep.
OCEdesigns likes this.
post #3 of 22 (permalink) Old 02-18-2019, 09:22 PM
Seems to me that you could lay the pistol and magazine out as you want them to show, then carefully trace around each. This could then be transferred using carbon paper to a thick piece of the same material with which you make the overall box. Double or triple check for size and accuray of the outline. Then trim it with a plunge router, just oversized enough to allow for the felt. Drop this into your finished box and you have a nice display.
You could using flocking for the lining, or felt. I would also consider drilling at least two holes on each side of the grip so you can get it out of the case without having to grab the trigger to lift it out.
MEBCWD and OCEdesigns like this.
DesertRatTom is online now
post #4 of 22 (permalink) Old 02-18-2019, 09:24 PM
MoHawk's Avatar
First Name: Bob
I have a .dxf file of a 1911 I used to make a display box. You may need to scale it to fit. I will try to message it to you.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4
MoHawk is online now
post #5 of 22 (permalink) Old 02-18-2019, 09:36 PM
First Name: Brian
Here is how I have done a handful of foam cutouts for cases.
I made a template using Fusion360. The template has parameters for length and height of the slide, overall length and height, grip angle, etc. That covers the basics for most autos. Things like the trigger guard and any unique profile of the grip, etc have to be added as appropriate, and with however much detail you want. I will say I arrived at this method after several attempts trying to capture every last detail of the shape. In the end less turned out to be more. On odd shaped protrusions like some sights or hammer, I tend to just cut a relief oversized rather than match it exactly.
So far all the pieces I've done were from the typical black or grey foam that comes with many cases. I have also done some tests in more rigid EVA foam. The EVA machines very nicely, and may be something that would work well for what you're trying to do.
Here's a screen shot of the template I made in Fusion. I will find some pics of the finished pieces also.
Brian
jpbldr is offline
post #6 of 22 (permalink) Old 02-18-2019, 10:03 PM
difalkner's Avatar
First Name: David
That's one of the most powerful features of Fusion 360, like Brian said. The ability to have one model and just modify the parameters means you can fit just about anything without redrawing. I'd love to see some pictures of the finished cases, too, Brian.
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #7 of 22 (permalink) Old 02-18-2019, 11:20 PM
MEBCWD's Avatar
It is best not to use pictures off the web to fit measurements to or fit vectors to. The problem, these pictures might be taken at a slight angle so your vectors could be off enough then parts might not fit.
Best thing is if you can find vector files from a manufacturer or from someone that has already created a file. Next best way is to have the actual item and take measurements from there.
This is just for items that need to fit with other items well. If the project is something like a sign to take up space on a wall then less than perfect pictures will work just fine.
MEBCWD is online now
post #8 of 22 (permalink) Old 02-18-2019, 11:44 PM
JOAT's Avatar
First Name: Theo
Yes, that worked nicely when I did it.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is online now
post #9 of 22 (permalink) Old 02-19-2019, 08:36 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Thanks for all the replies and the PM!
It looks like I was really over thinking how to do this. Now I have plenty of options. I'll probably do a few display cases now if it is this easy! LOL I guess this is definitely part of the learning curve with this machine and the capabilities of the software.
post #10 of 22 (permalink) Old 02-19-2019, 09:51 AM
Knothead47's Avatar
FWIW, open display of firearms is an invitation to thieves. A casual remark, word gets out, the wrong people hear and they are gone. Speaking from experience.
John T.
Life is like water-skiing; if you slow down, you go down.
Knothead47 is offline
Seeking routing advice router king General Routing 24 08-21-2016 12:11 PM
Sketchup: Restore a lost or corrupted file gmercer_48083 General Routing 4 08-29-2015 07:04 PM
The easiest way to transfer a file from Solid Works file to an Aspire file? NRG 4055 CNC Routing 4 10-09-2013 10:12 PM
Outlook Express problems BrianS Lobby 6 01-06-2008 08:23 AM
