gcode - Router Forums
 3Likes
  • 1 Post By ger21
  • 1 Post By ger21
  • 1 Post By OCEdesigns
post #1 of 9 (permalink) Old 02-23-2019, 06:37 AM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
Default gcode
hi guys i have a compass h 1000 and am using aspire 9.011 with mach3
the problem im having is when i try to load any gcode i make in aspire it loads high and to the right
as a result my cnc goes out of limits before it starts
but the roadrunner gcode that comes with mach3 loads fine and cuts fine any help would be great
ps im a total newbi to cnc thanks Dave
daved210 is offline
post #2 of 9 (permalink) Old 02-23-2019, 08:57 AM
difalkner's Avatar
First Name: David
I don't use Aspire so not sure, but are there different Post Processors from which to choose? It could be that your Post Processor doesn't match your machine setup.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 9 (permalink) Old 02-23-2019, 09:22 AM
First Name: 4D
If you are using the correct post processor, then check the Home/Start Position on the Material Setup menu you can access on the toolpath side. This feature normally lets you set where the bit starts and finishes relative to the origin. I'll use it when I want to avoid clamps near the origin. Aspire remembers this setting from job to job so if you've set it in one job you'll need to change it back in the next job else your spindle may roam somewhere unexpected at start of a job.
4D
4DThinker is offline
post #4 of 9 (permalink) Old 02-23-2019, 09:36 AM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
I checked with cau cau and they said the post processor was the one for my CNC
daved210 is offline
post #5 of 9 (permalink) Old 02-23-2019, 09:41 AM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
Not sure they are right have tryed lot in the program all seem to be the same thanks
daved210 is offline
post #6 of 9 (permalink) Old 02-23-2019, 09:53 AM
ger21's Avatar
First Name: Gerry
What do you have here when starting a new file?
MEBCWD likes this.
Ger
www.cncwoodworker.com
ger21 is offline
post #7 of 9 (permalink) Old 02-23-2019, 10:44 AM
ger21's Avatar
First Name: Gerry
Also, are you setting your X any zero positions on your machine. The XY zero on your machine needs to match what you are setting in Aspire.
MEBCWD likes this.
Ger
ger21 is offline
post #8 of 9 (permalink) Old 02-23-2019, 01:21 PM
OCEdesigns's Avatar
First Name: Chad
I have a thread here about this as well and what Gerry says here ^^^^ was my issue. I was setting my start X, Y, zero in one place in my program but setting my work piece X, Y, zero in another.
MEBCWD likes this.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #9 of 9 (permalink) Old 02-23-2019, 10:48 PM
MEBCWD's Avatar
Because the roadrunner file loads and cut correctly tells me you are setting up and zeroing on your board. So I would say your design file start point is different from where you are zeroing or you have accidentally set up an offset in the Setup menu.
Name:	offset problems.jpg
MEBCWD is online now
digitizing a small boat plan and cutting the parts woodman12 CNC Routing 4 05-29-2018 08:42 PM
Dual Y Axis control Daner CNC Routing 5 09-29-2017 07:40 PM
saving work for cnc router blacktrain CNC Routing 9 04-14-2017 12:23 PM
Vcarve 7.5 Output to Gcode for CNC Shark Control Panel Cncsigns1954 CNC Routing 9 02-26-2015 02:36 PM
eagle gcode problem rambo900 CNC Routing 1 10-05-2013 10:21 PM
