Vacuum Table - Router Forums
 2Likes
  • 1 Post By MEBCWD
  • 1 Post By 4DThinker
post #1 of 8 (permalink) Old 02-27-2019, 09:56 PM Thread Starter
First Name: Mark
Default Vacuum Table
I was wondering if anyone had any secrets or input into being able to hold PETG or Lexan sheets to a CNC router table. I am running a KOMO MACH II router with a very good vacuum pump and have no issues at all holding MDF and other woods but I am having a real hard time holding plastics to the table. They lift off of the table with hardly any effort and move around when being machined. Any input would be appreciated.
Thx
Marko63 is offline
post #2 of 8 (permalink) Old 02-28-2019, 08:06 AM
ger21's Avatar
First Name: Gerry
Are they thin sheets? What type of tooling are you using? If you are using upcut bits, try straight flute bits that won't lift.
Ger
www.cncwoodworker.com
ger21 is offline
post #3 of 8 (permalink) Old 02-28-2019, 08:15 AM
difalkner's Avatar
First Name: David
Welcome to the forum! When you get a minute add your first name to your signature line to clear the N/a in the side panel.
Got any photos of your setup? That sometimes helps with suggestions.
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #4 of 8 (permalink) Old 02-28-2019, 12:24 PM
MEBCWD's Avatar
Welcome to the Router Forums.
Here is a link to a video that might have a solution for you, it's worth a try
You can jump to 5:45 and see what he has found to help him.
difalkner likes this.
MEBCWD is online now
post #5 of 8 (permalink) Old 02-28-2019, 02:04 PM Thread Starter
First Name: Mark
Sheets are 1/8" thick. I have tried upcut and down cut. Upcut lift the sheets. Cutting on a MDF spoil board and never have any issues with other material but very evident when cutting PETG, Lexan and Plexiglass for some reason.
Marko63 is offline
post #6 of 8 (permalink) Old 02-28-2019, 02:46 PM
MEBCWD's Avatar
Mark try the newsprint and see if it helps, it won't cost you much to do a test.
post #7 of 8 (permalink) Old 02-28-2019, 06:11 PM
First Name: 4D
My fabrication lab tech uses masking tape around the perimeter of thin sheets to keep the vacuum holding onto the parts being cut. This is on a Multicam CNC with vacuum bed sucking through MDF.
4D
timon2jkl likes this.
4DThinker is offline
post #8 of 8 (permalink) Old 03-01-2019, 02:28 PM
I apologize if I am stating the obvious, but make sure you are covering whatever part of the vacuum table, or zone, that is not being covered by the sheet. think I heard that vacuum can wander 2-3" in the mdf spoilboard past the sheet being held...
TimPa is online now
Rockler Vacuum Chuck CharleyL Tools and Woodworking 15 08-09-2017 10:57 AM
Vacuum table RainMan 2.0 CNC Routing 2 03-25-2017 01:23 PM
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
Resurrected bird table Coleve Show N' Tell 16 12-07-2013 07:05 AM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 10:51 AM
