jpbldr's projects - Router Forums
 55Likes
post #1 of 30 (permalink) Old 03-03-2019, 01:20 AM Thread Starter
First Name: Brian
Default jpbldr's projects
I rarely find the time to post a new thread when I do something on my CNC machine.
At the same time, I read daily what others are doing, and find projects posted by others, especially if there are pics, the most inspiring. The specific project may not even be of interest to me, but seeing their process, and how they overcame whatever problems they encountered, if any, always seems to help advance my process.
So, I have started this thread to post up things I have done using my Probotix Comet CNC. I use Fusion 360 for design and CAM. I started using Fusion about 3 yrs before I bought the CNC, so at least had a decent grasp on the 3d design process and had run many CAM simulations prior to taking the step of buying a machine that could put that to use. I am by no means an expert.
That said, I will start posting pics of various projects I have completed, and give a brief description. I hope this provides the same inspiration to others that I have experienced.
This first pic is one of the first things I "cut" successfully. The end result, a flying model of an F22, wasn't quite right. But several revisions later, and with a better feel for running the CNC, I have a well flying model, and have continued to update the design, and have cut, built, and flown several. These are cut from "dollar store foam board", and it turns out this material has also worked well for me in testing patterns for various things before cutting in the "real" material. Cutting this material on top of a foam block as spoilboard, let me learn the CNC with less fear of crashing it.
jpbldr is offline
post #2 of 30 (permalink) Old 03-03-2019, 01:31 AM Thread Starter
First Name: Brian
Here is the latest revision of that model, test fit dry, ready for final assy. and electronics. Sitting on another project from the CNC This one flies well
jpbldr is offline
post #3 of 30 (permalink) Old 03-03-2019, 01:58 AM Thread Starter
First Name: Brian
Under the model plane is a motorcycle stand. Made from 1/2" ply. Tabbed and slotted edges, glued on final assembly. The rubber top is a piece of baler belt, also cut to shape and pocketed for fasteners on the CNC.
jpbldr is offline
post #4 of 30 (permalink) Old 03-03-2019, 02:18 AM Thread Starter
First Name: Brian
Here are some signs I made for my dad's property. Fusion 360 text boxes have some quirks, hence the one that's off center. No matter here, as the blanks were salvage drawer fronts, and the edges were all cut down to a tight margin for final sizing. Other than the issue I had with centering at first, V-carve, or "engrave", as it's called in Fusion CAM, is pretty cool to see in action. These were perhaps the most simple project I've done, and if one wanted to just do simple text based signs, these could be cranked out easily, and quickly.
That's all for tonight. I will add more when I get some more pics transferred. And, any questions or comments are welcome.
Brian
jpbldr is offline
post #5 of 30 (permalink) Old 03-03-2019, 02:47 AM
Thanks for posting the pic's. I am not a CNC-er, but like to see the projects that you guys turn out. Good job on the planes.
Herb Stoops is offline
post #6 of 30 (permalink) Old 03-03-2019, 07:46 AM
difalkner's Avatar
First Name: David
Good job on all, Brian! Glad to see your projects and looking forward to more. I also use Fusion 360 but have done very little 3D work.
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #7 of 30 (permalink) Old 03-03-2019, 08:52 AM
First Name: Ray
Hi Brian:
Your projects look great! I too have a Probotix Comet and have had it for about 5 years. Love the darn machine! I use Aspire which has served me quite well although I am not always able to do 3D modeling easily. Probably my fault for not spending the time to fully grasp the process.
Several years ago I purchased a 3D printer (which I love almost as much as the Comet). I started to use Sketchup 2018 (free version) to create the models and output STL files. I did not look at Fusion 360 because I didn't want to pay for it. Now there are a few ways to get Fusion for free so I have started to take a closer look. I am wondering if I should spend time learning Fusion in hopes that I can drop Aspire and Sketchup? Would appreciate your thoughts.
difalkner and Scottart like this.
rayk2 is offline
post #8 of 30 (permalink) Old 03-03-2019, 10:20 AM
Gaffboat's Avatar
First Name: Oliver
Thanks, Brian. Seeing other’s projects and photos is one of the things that keeps me coming to the forum. I often learn something new, discover a shortcut, or find something I can adapt to my own projects. I enjoyed seeing that you were able to cut “dollar store foam board” on your CNC. I may use that in a future project and never would have considered without your post. Keep posting your stuff.
MEBCWD and Scottart like this.
Gaffboat is online now
post #9 of 30 (permalink) Old 03-03-2019, 11:46 AM
RainMan 2.0's Avatar
Thanks for sharing Brian , you’ve done some nice work there . Was hoping to get more pics of the jet as it progressed . Neat hobby
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 30 (permalink) Old 03-03-2019, 11:50 AM
ger21's Avatar
First Name: Gerry
Aspire and Fusion 360 are very different programs. There are different operations that are much easier done in one or the other.
Aspire is much better at V Carving that Fusion 360.
Aspire has a lot of tools specifically for 3D relief modelling. Fusion 360 does not.
IMO, most 2D CNC operations can be done much more quickly than in Fusion 360, if you are proficient with Aspire's drawing tools.
Fusion 360 has a ton of features that Aspire does not.
Parametric modeling
Assemblies
High quality rendering.
Lots more toolpath options.
Many, many other things.
There is no perfect software package that does everything. I probably use at least 5 or 6 different programs for my CNC work.
Aspire, Fusion 360, AutoCAD, MeshCAM, Lightwave (3D modeler). Whatever it takes to get the job done.
SteveMI, difalkner, MEBCWD and 4 others like this.
Ger
www.cncwoodworker.com
ger21 is offline
Planning projects for wood movement Duane Bledsoe Tools and Woodworking 27 10-13-2015 10:39 PM
Choosing the best wood for outdoor projects Hamlin Wood Species 5 07-21-2009 08:40 PM
