Best bit for 3D finish pass - Router Forums
 21Likes
post #1 of 13 (permalink) Old 03-08-2019, 02:43 PM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Default Best bit for 3D finish pass
I have done several 3D clip art designs that came with the VCarve Pro software I have (and a few from the internet). So far I have used an 1/8th inch ball nose end mill for my finish pass. What does everyone use? I'm mostly happy with the finish but looking to see if I can get a better finish so I have less sanding to do. I have a 2 flute 7.5 degree V-Groove engrave bit with a 1/16" tip that I am wanting to try. This one >>> https://www.freudtools.com/products/70-103 Just looking for opinions before I try it this weekend.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #2 of 13 (permalink) Old 03-08-2019, 05:31 PM
ger21's Avatar
First Name: Gerry
What type of finish issues are you seeing?
The tool won't effect the finish much.
That's more dependent on wood species, and sometimes cut direction, feedrate and rpm.
Stepover may also play a role. For as really good finish, you want to use maybe a 5%-8% stepover. But the smaller the stepover, the longer the run time.
Most people use tapered ballnose bits, like these:
https://www.amazon.com/SpeTool-Tungs...ateway&sr=8-21
MEBCWD, Gaffboat and OCEdesigns like this.
Ger
www.cncwoodworker.com
ger21 is offline
post #3 of 13 (permalink) Old 03-09-2019, 07:54 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Gerry,
Thanks for the reply. The finish is not bad. I was trying to get it to be smoother so I have less sanding in the difficult areas, and before I start doing some of the more detailed pieces. I looked at my step over and one piece that I ran I had a 25% step over. That may be my biggest issue! I'll try a 5%-8% like you suggest. I will also buy the bit you suggest. I have seen those but was not real sure if I could use those so THANKS for clearing that up for me!!
post #4 of 13 (permalink) Old 03-09-2019, 09:39 AM
If it's a smaller cut you can also run the finish toolpath twice. Once in climb and then conventional. They cut in opposite directions. Eliminates a lot of fuzzies.
Also, I have found out - the softer the wood, the sharper the bit has to be. Especially with pine and poplar. Aspen Vcarves nice, but not so good 3d. A good sharp bit eliminates a lot of fuzzies. Try the Spectras from Toolstoday.com. I get mine sharpened (about $7) now, if they don't break, and probably change more frequently than needed. A smaller stepover helps a lot too.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is offline
post #5 of 13 (permalink) Old 03-09-2019, 10:18 AM
Pro4824's Avatar
First Name: Joe
I use JERRAY CNC Carving 4.82 Deg Tapered Angle Ball Tip radius=0.5mm X 1/4" Shank tungsten Solid Carbide HRC55 with TiAIN Coated Router Bits https://www.amazon.com/dp/B015C61XX4..._5a-GCbHTCHHGX
It's only $16 and still sharp after about 20 projects in wood and bronze.
6% stepover.
MEBCWD, Gaffboat, MoHawk and 3 others like this.
Pro4824 is offline
post #6 of 13 (permalink) Old 03-09-2019, 10:18 AM Thread Starter
OCEdesigns's Avatar
First Name: Chad
More great info that I didn't know! Thanks! I'll try these too.
honesttjohn likes this.
post #7 of 13 (permalink) Old 03-09-2019, 10:37 AM
chessnut2's Avatar
I also learned some things here today. Thanks.
honesttjohn and OCEdesigns like this.
chessnut2 is offline
post #8 of 13 (permalink) Old 03-09-2019, 11:03 AM
And sometimes you get a piece of wood that won't cut clean, no matter what you do.
I also have found out that (depending on the project) you don't have to have a completely smooth surface, especially if staining. When you wipe the stain it will lay a lot of the rough ends right down, and actually remove fuzzies in nooks and crannies if you use a rag with a small tool to go over it. An extra coat or 2 of poly makes things smoother (light sanding between the last couple of coats) too. And if you paint, you can hide even more imperfections -- just ask Scottart.
Don't be too critical of what you consider "mistakes". Others normally don't even notice, and the piece has it's own "character." No matter how hard you try, it'll never be perfect in your eyes.
MEBCWD, MoHawk and OCEdesigns like this.
HJ
Detroit Burbs
post #9 of 13 (permalink) Old 03-09-2019, 01:38 PM Thread Starter
OCEdesigns's Avatar
First Name: Chad
Thanks John for all the great information!
post #10 of 13 (permalink) Old 03-09-2019, 06:51 PM
First Name: Gary
You can also try some 3M Radial Bristle Discs that can be used with a Dremel. You can find them on Amazon in various grits. They are thin, but can be stacked for use on larger, open areas.
Sorry, but I haven't posted enough times to add a link.
Gary
OCEdesigns likes this.
gmedwards is offline
Eagle America Keepsake Box Router Bit gdonham1 Router Bits - Types and Usage 1 11-20-2018 10:06 AM
Stripes after finish pass on pocket bottom luclefleur Router Bits - Types and Usage 14 05-16-2018 04:30 AM
Router Accident - Trying to understand what happened Darryl Shop Safety 170 07-07-2017 06:44 PM
Box joints and bit depth - one pass? Toy Sun Table-mounted Routing 10 03-21-2015 08:07 AM
Removing a stuck bit from a Makita RP1800 Big_Ren General Routing 16 02-27-2015 01:01 AM
