Size of project - Router Forums
post #1 of 23 (permalink) Old 03-12-2019, 12:12 PM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
Default Size of project
Hi guys every time I design a project in aspire 9.011 and bring it to my CNC it only comes out half the size i have checked my setup in Mach3 and setup all axis using mach 3 it all seems fine when I run the checks but when I load my gcode and start cutting it only cuts the project half the size any help please
Ps can the post processor be the problem
Thanks Dave
daved210 is offline
post #2 of 23 (permalink) Old 03-12-2019, 09:43 PM
First Name: 4D
A couple of things to check: Are you using the right post processor for your CNC? Has the CNC been properly set up/configured?
4D
4DThinker is offline
post #3 of 23 (permalink) Old 03-12-2019, 09:45 PM
ger21's Avatar
First Name: Gerry
Which post processor are you using?
My guess is that you have Mach3 setup incorrectly.
In Mach3. under Config, Native Units, is it set to the correct units? (mm I assume?)
Then, make sure you are currently in that mode (G21 for mm, G20 for inches).
Zero the axis, and use MDI to move a certain distance. If the distance is wrong, then your steps/unit is wrong.
Ger
www.cncwoodworker.com
ger21 is offline
post #4 of 23 (permalink) Old 03-13-2019, 06:38 AM
ger21's Avatar
First Name: Gerry
I'm pretty sure that your steps/unit are incorrect.
What type of machine is this? Did you configure Mach3 yourself?
From your PM, you are using the standard Vectric Mach3 metric post. This post is used by thousands of people without problems.
Ger
ger21 is offline
post #5 of 23 (permalink) Old 03-13-2019, 08:24 AM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
Yes I set it up myself this is my machine the only difference is I have profi4 not 3 I purchased it second hand at an auction in Ireland thanks
daved210 is offline
post #6 of 23 (permalink) Old 03-13-2019, 08:36 AM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
Ps there where no manuals with it also I'm a total newbie to the CNC world so maybe I didn't set up Mach3 right
daved210 is offline
post #7 of 23 (permalink) Old 03-13-2019, 08:58 AM
OCEdesigns's Avatar
First Name: Chad
I am using VCarve Pro and I had a similar problem and for me it was the post processor I chose. Once I was told the correct one to use it has been fine.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #8 of 23 (permalink) Old 03-13-2019, 09:18 AM Thread Starter
daved210's Avatar
Country: Ireland
First Name: Dave
I was told to use mach2/3 mm .txt but it's not working for me when I set my zeros and click start it starts and wonders off to the far right
daved210 is offline
post #9 of 23 (permalink) Old 03-13-2019, 10:36 PM
ger21's Avatar
First Name: Gerry
It's most likely going to the home position as specified in Aspire. That is normal
Upload your g-code and Aspire file.
Ger
ger21 is offline
post #10 of 23 (permalink) Old 03-13-2019, 10:37 PM
ger21's Avatar
First Name: Gerry
Both the Mach2_3_Arcs_mm and Mach2_3_ATC_Arcs_mm should work fine.
Neither are likely to be the problem.
Ger
ger21 is offline
need advice on project please lking Tools and Woodworking 7 03-06-2019 12:11 PM
Self pinging of router fails below MTU size in putty livin Lobby 14 12-23-2012 10:46 PM
My Custom DIY Insert Plate / Router Table Project BRAVOGOLFTANGO Table-mounted Routing 21 10-17-2012 09:52 PM
First major project docwva Starting Off 12 04-24-2012 08:43 AM
