My CNCs first bath. - Router Forums
 17Likes
post #1 of 11 (permalink) Old 03-16-2019, 10:04 PM Thread Starter
Pro4824's Avatar
First Name: Joe
I "attempted" to mill a horse in a black granite tile. The Z was way off due to flex in the plastic tub but the horse test was just to confirm the machine could handle granite before going deeper into the rabbit hole. 🙂
I've got a long way to go but you sure can't do that with a laser!! 😉
https://youtu.be/j00_463IIxc
Pro4824 is offline
post #2 of 11 (permalink) Old 03-16-2019, 10:31 PM
RainMan 2.0's Avatar
Wow , very cool !
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 11 (permalink) Old 03-16-2019, 10:34 PM
difalkner's Avatar
First Name: David
What bit did you use, Joe? Sounds like your spindle is up pretty high, too. Did the water stay cool for the entire cut? Good job, btw!
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #4 of 11 (permalink) Old 03-16-2019, 11:47 PM
old55's Avatar
First Name: Ross
Nice.
Ross,
old55 is offline
post #5 of 11 (permalink) Old 03-17-2019, 09:18 AM
sreilly's Avatar
First Name: Steve
I suspect that using a CNC system is a bit of a learning curve but you seem to have got it working well. Seeing and recognizing the issues as they happen goes a long way to getting the results you want/need. Looks like you're well on your way. Looks great to me Joe.
sreilly is online now
post #6 of 11 (permalink) Old 03-17-2019, 10:34 AM Thread Starter
Pro4824's Avatar
First Name: Joe
Thanks guys, until I get the kinks worked out, the granite milling is (for entertainment purposes only) 🙂
David, yep that's 24,000 rpm for the finishing pass with this bit.
Diamond 40 Degree PCD Cutter (3683) https://www.amazon.com/dp/B075BHLWBT..._TVKJCbWH3ZXAW
The roughing pass is 18,000 rpm with this bit.
Diamond Sintered Router Bits Straight Finger Burs for Granite Stone (C) https://www.amazon.com/dp/B07J1VYJJG..._VyLJCbKNBN4N4
Cutting submerged is my only option for now but from my research, everyone is using water cooling like this one so I'll be rigging it up soon. That way I can see what's going on instead of just looking at a tub of muddy water and wondering... 🙂
OriGlam Mist Coolant Lubrication Spray System https://www.amazon.com/dp/B071DXGGP4..._JeLJCbYHEHJJP
I saw a lot of feeds and speeds recommending 10-15 inches per minute so that's where I started but with the 6% stepover, that was gonna be about a 26 hour horse. 😞 and not worth doing. So I bumped everything way up to 12% stepover and 120 IPM
and finished the horse in 2.5 hrs. I think I can get it down to an hour without breaking anything but we'll see. 🙂
MEBCWD, swarfmaker, MoHawk and 1 others like this.
Pro4824 is offline
post #7 of 11 (permalink) Old 03-17-2019, 06:03 PM
MEBCWD's Avatar
Joe looks good to me. Looks like you found reasonably priced bits to use and they did a good carve. The air-water cooling system you found looks like it would also help improve on the granite work. I think I would try to keep the stepover around 10% and mess with the other parameters to help keep a smooth 3D cut. You might also make a tray from plastic with a flat bottom to get rid of the flexing or make something to go into the tub that rests on the low portions and supports the work.
Joe thanks for posting this. Looks like you will push the limits of your new machine and then some. I look forward to seeing how far you can PUSH those limits.
MEBCWD is online now
post #8 of 11 (permalink) Old 03-18-2019, 08:51 AM
OCEdesigns's Avatar
First Name: Chad
Looks grate to me! Thanks for posting this up. It shows that the limits to these CNC machines are only in our heads! I'm sure this gives people (including myself) ideas on other projects!
And thanks for posting up the links to the bits used. that is a big help also!
MEBCWD and Gaffboat like this.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #9 of 11 (permalink) Old 03-18-2019, 02:43 PM
Scottart's Avatar
First Name: Scott
OK, that is a crazy water bath idea. That is mine stretching. thanks for posting.
Man with out Vision shall perish..women too!
Find more of our stuff on Etsy
https://www.etsy.com/shop/CreekWillo...platform-mcnav
Scottart is offline
post #10 of 11 (permalink) Old 03-25-2019, 10:14 AM
First Name: mary
very cool but how did you hold it down?
marecat3 is offline
Probotix CNCs, Square and Plumb 4DThinker CNC Routing 56 02-12-2019 02:01 PM
Bath Vanity Mod MT Stringer DIY and Renovation 13 10-29-2015 05:01 PM
Went looking at new CNC's honesttjohn CNC Routing 11 03-04-2015 10:33 PM
What color tile and paint for bath? TramondKrick Wood Species 11 08-10-2012 02:20 AM
Finishing the down bath in cherry xplorx4 Show N' Tell 1 02-25-2011 06:55 AM
