DIY CNC in new Woodsmith - Router Forums
 8Likes
  • 3 Post By tomp913
  • 2 Post By sreilly
  • 1 Post By MEBCWD
  • 2 Post By Bruce Macdonald
post #1 of 10 (permalink) Old 03-19-2019, 07:48 PM Thread Starter
Default DIY CNC in new Woodsmith
Just got the new Woodsmith magazine and it had the first of a two-part article on building your own CNC. Only skimmed it so far, but it looks as if the bed and frame are made out of plywood, with the bed made as a torsion box. Second part will cover building the working parts.
TimPa, Danman1957 and TenGees like this.
tomp913 is online now
post #2 of 10 (permalink) Old 03-20-2019, 08:42 AM
sreilly's Avatar
First Name: Steve
Interesting article for sure. Looks like a high level of detail and what a better way to understand how a tool actually works. I wonder how it stands up to ready made? Looks like a Stumpy Nubs type project.....
RainMan 2.0 and twmv86 like this.
sreilly is online now
post #3 of 10 (permalink) Old 03-20-2019, 03:53 PM
MEBCWD's Avatar
Interesting, the guide rails for the Y axis are made from plywood and they are guiding metal V bearings. I wonder how long it will be before the rails fail!
RainMan 2.0 likes this.
MEBCWD is online now
post #4 of 10 (permalink) Old 03-20-2019, 04:19 PM
sreilly's Avatar
First Name: Steve
So if you're a member see this link for the video
post #5 of 10 (permalink) Old 03-21-2019, 04:41 AM
In the "Sawdust" editor's note at the front of the magazine, Vince notes that Chris, the designer, built the prototype 4 years ago and has used it ever since in his personal shop. Seems like it it's robust enough to last quite a while.
Dan1951 is offline
post #6 of 10 (permalink) Old 03-23-2019, 10:02 AM
Gaffboat's Avatar
First Name: Oliver
The plans call for the plywood rails to be capped on both edges with aluminum angle to provide a long-wearing surface for the V-bearings. I don't think I would build one, but with an estimated cost of $1,300 for all materials and parts (not including the cost of software), it might be a way for someone to get into CNC work. The 24" x 48" bed area is also an attractive feature.
Gaffboat is online now
post #7 of 10 (permalink) Old 03-23-2019, 12:18 PM
UglySign's Avatar
First Name: Ronnie
A machine like that is very safe for cutting polyiso.
UglySign is online now
post #8 of 10 (permalink) Old 03-23-2019, 12:55 PM
MEBCWD's Avatar
I just wonder if the rails will hold up against the constant movement of the gantry with the added weight of the router. The rails are only supported at five points spaced a foot apart but they are mounted to a torsion box. I do know they say the prototype has been running for a couple of years. I went to their website to see what electronics they were using but they were not listed like the magazine suggests. I guess they will update their site when the next issue is released.
post #9 of 10 (permalink) Old 03-23-2019, 04:21 PM
RainMan 2.0's Avatar
Tom , I can’t find the article, but
this is a Joes cnc , and to keep costs down Joe uses metal angle iron for the V bearings to ride on.
The V bearing also need to be continually adjusted as the angle iron wears. I was going to build this version myself,as to me it’s the best bang for the buck , but I’m really wanting use linear bearings now .
At 10:30 you can see how the carriage works on the rails
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 10 (permalink) Old 07-03-2019, 03:53 PM
Default Woodsmith CNC router
Hi all,
I am almost complete on the Woodsmith CNC router build. See my blog in Lumberjocks for details.
lumberjocks.com - topics - 303929
I can assure you the rails are very robust and I am convinced they will last a long time. It's a great build but room for improvement. The pics below are quite old, I'll get some new ones up.
Feel free to contact me if anyone wants to discuss the build.
ddop and OCEdesigns like this.
Bruce Macdonald is offline
DIY CNC router - Original design BalloonEngineer CNC Routing 22 09-06-2019 01:01 AM
