Blind Mounting ACP to Stone - Router Forums
post #1 of 5 (permalink) Old 03-26-2019, 04:04 AM Thread Starter
Gary Wiant's Avatar
First Name: Gary
Default Blind Mounting ACP to Stone
I hope this is the right sub forum to post this.
I have a customer that wants me to route out his logo and blind mount it onto a large stone (I think it is sandstone because it was sandblasted at one time). What I've came up with is cnc riuting 2 logos for each side out of 6mm ACP & drilling counter sunk holes into the back logo then mounting anchors into the stone & bolting the back logo sold then using some type of epoxy to mount the front logo to the back logo. All hardware MUST BE stainless I don't want it to rust.
My questions does this sound like the most perminate way to do this?
Will the sandstone hold the anchors? & what are the best anchors to use in sandstone for durability?
What type of adhesive / epoxy would be best to mount the 2 logos together? I dont want to see a gap between the 2 pieces. Has anyone ever used any of the Lords adhesives?
Thank you
Gary
I'm here to learn about CNC routing & anything else I can pick up.
God bless
Gary Wiant is offline
post #2 of 5 (permalink) Old 03-26-2019, 06:14 AM
UglySign's Avatar
First Name: Ronnie
Yes for the Lord... Maxlok MX/T18 - Scuff & clean well the surface prior to. MX/T3 & 6 have short working time & dry fast.
You'll need the dispenser gun & mixing straws (get extra straws). Worth it for future use.
After using MX, cap it & keep refridgerated, it will last longer as the shelf life less than a year AFAIK.
Hilti anchors?
Stainless Steel & Aluminum together will corrode.
UglySign is offline
post #3 of 5 (permalink) Old 03-26-2019, 06:26 AM Thread Starter
Gary Wiant's Avatar
First Name: Gary
Thank you, What color is the Lord's? How long of a working time does the MX/T18 have? Will it need clamped until it dries?
Will it work to mount the anchors to the stone?
Any ideas on creating the standoffs?
Am I right that the corrosion with aluminum & stainless will only occur on raw aluminum?
The ACP will have a backed enamel finish, we always use stainless to install ACP signs and have never had any issues
Thanks again.
God bless
post #4 of 5 (permalink) Old 03-26-2019, 08:20 AM
UglySign's Avatar
First Name: Ronnie
For us its been a dark grey and working time is ~20 mins
Clamps, weight or tape. Vertical gluing needs a creative approach.
Standoffs? For folded pan face style we would CNC cut Sintra/PVC
so it doesnt collapse depending on application.
Another way, 1/4" pin locations.
On the back logo face side go halfway lets say 1/4"dia.
On the front logo on the back side go half way w/ 1/4"dia. - Use a small 1/4" dowel/rod to align in place.
Use whatever you have on hand.
Just like when you do 2-sided routing in VCarve and register in the spoilboard. Know what I mean?
It registers the logo to the back panel but you'd still have to clamp it however.
As for the corriding, I fig'd you knew this but I wrote it anyways.
The sides of ACP/SS can & would corrode eventually & probably wouldnt
be noticeable for a long time.
UglySign is offline
post #5 of 5 (permalink) Old 03-26-2019, 09:08 AM Thread Starter
Gary Wiant's Avatar
First Name: Gary
Yes the bare edges of the acp. I understand what you mean about the pinning. I have not done any 2 sided routing because I have a vacuum table & I do not want to drill into the spoil board.
I'm planning on using 6mm ACP so I'd only be able to drill 1/8" deep pockets for the pins but I think that would be enough to hold them together while the lords dries.
Now to figure out mouting the anchors to the stone
Thanks a lot
God bless
A mounting plate tutorial by BobJ3 Mike General Routing 11 07-14-2016 05:07 PM
Home Renovation TRN_Diesel Project Plans and How To 99 07-26-2014 10:25 PM
