Biesse Rover S error codes - Router Forums
 1Likes
  • 1 Post By ger21
post #1 of 3 (permalink) Old 03-26-2019, 11:38 PM Thread Starter
Post Biesse Rover S error codes
We have a Biesse Rover S 1224 LOAD &UNLOAD MACHINE.
There list errors:
PLC 90197,
PLC90118
PLC90102
PLC9469
What happened of machine? How can we solve these issues?
NEWCG is offline
post #2 of 3 (permalink) Old 03-27-2019, 07:04 AM
ger21's Avatar
First Name: Gerry
Do you have a manual with a lost of errors?
If not, you probably need to call Biesse.
I'm assuming shutting down and restarting does not clear the errors?
You could open the control cabinet and check for loose wires.
TimPa likes this.
Ger
www.cncwoodworker.com
ger21 is offline
post #3 of 3 (permalink) Old 03-27-2019, 11:58 PM
MEBCWD's Avatar
From what I understand there are breakers inside the control panel door. One or more may have tripped. Make sure all of them are okay and restart. You might be better off just contacting Biesse to find out what the codes are like Gerry suggested.
MEBCWD is offline
Need Help Biesse Rover 30 manual Frank13 General Routing 3 04-04-2018 03:43 PM
Biesse Rover 322 akdenyer CNC Routing 1 10-06-2011 10:32 PM
Biesse rover b2.30 woodart New Member Introductions 1 12-07-2010 10:42 AM
Selling Biesse Rover 20 atlasrob CNC Routing 0 12-30-2009 08:43 AM
Issues with Biesse Rover 24? TemeculaTom Tools and Woodworking 0 08-07-2009 07:21 PM
